Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-22-2014, 09:29 AM   #1
samsonr1
Drives: 2014 ZL1 M6 SW
rim and tire question
In order to put all season tires would it work if I buy 2 of these http://www.phastekperformance.com/mo...O-ZL1-20x10-BG and put them on the rear of the car and then buy 285 all seasons for all 4 wheels? Does anyone see any issues arising?
Also, if anyone knows of a set of all seasons that will fit the car that would be very helpful. Even if they are larger or smaller but still fit the rims and drive well, that is ok with me.
samsonr1 is offline   Reply With Quote
Old 07-22-2014, 09:37 AM   #2
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
It will work, but look funny. Those are gloss and stock ZL1 wheels are more matte/satin. Offsets and tire sizes would work though.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 07-22-2014, 11:03 AM   #3
samsonr1
Thanks for clarifying. Are there any replicas that are exactly like the stock ones and does anyone have experience with replicas and do you recommend them?
Old 07-22-2014, 11:16 AM   #4
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
I looked. They have a satin version. Those would match up fine. They also have a 20x10 +35 that would tuck it under the fender a little more. You couldn't rotate those though.
Old 07-22-2014, 11:22 AM   #5
samsonr1
I assume the stock front rims are +23 offset?
Old 07-22-2014, 11:34 AM   #6
Irishblackcoffee
Irishblackcoffee's Avatar
Drives: 13 1LE GBE M6, 12 VR M6 #872
I have the same rims on my 1LE. They look really good.
'13 1LE "MAX" '12 ZL1 "SAPPER"
Irishblackcoffee is offline   Reply With Quote
Old 07-22-2014, 11:39 AM   #7
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Not sure if stock front is +23 offset. It's never good to assume though. The offset should be stamped on the back of the wheel spokes. Pull a wheel off and look. Or call the dealer. But I'm not sure I would trust some of the knuckleheads I've dealt with at a dealer.
Old 07-22-2014, 12:04 PM   #8
samsonr1
I messaged phastek asking if those rims are the same offset as stock front, we will see. I believe these are the tires I am going to go with, hopefully they can grip in the rear. http://www.tirerack.com/tires/tires....omCompare1=yes
Old 07-22-2014, 12:53 PM   #9
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
Wheel measurements are below. You should have no issues with this wheel fitting the rear of the car.
ZL1-Style Wheel: 20x9" w/ +27mm Offset (Correct offset for mounting on the front of the 2010+ Camaro)
ZL1-Style Wheel: 20x10" w/ +35mm Offset (Correct offset for mounting on the rear of the 2010+ Camaro)
ZL1-Style Wheel: 20x10" w/ +23mm Offset (Stock ZL1 Front Wheel Size w/ offset for mounting on front of the Camaro)
ZL1-Style Wheel: 20x11" w/ +43mm Offset (Stock ZL1 Rear Wheel Size)
Now you can mount the 23mm offset wheel in the rear but the wheel will not sit as flush with the fender as the 35mm offset. But if you are looking to just have an all season tire on there it should not be a problem.
Ricardo@Phastek is offline   Reply With Quote
Old 07-22-2014, 01:14 PM   #10
samsonr1
Thanks very much for the reply. Maybe I am better off with the +35 offset since my goal here is just to keep the stock look but have all season tires since the stock tires really aren't practical for safe daily use especially rain. I just haven't seen anyone else on here try what I am talking about doing on a zl1.
Old 07-22-2014, 06:01 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
I have The 23 offset all the way around like the 1LE in gloss square set up for rotation on michelin AS3. Half the noise, very quite, and no side splatter from every loose pebble in the street. Every car event I go to every Zl1 owner wants these wheels over satin. My stock rims still in the basement with Goodyears. On second thought I think the satins are the way to go...
ZMEnow is offline   Reply With Quote
Old 07-22-2014, 06:05 PM   #12
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
You could call factory reproductions since that is where phastek gets them from......FYI
CHMSC is offline   Reply With Quote
rim, tire
