JDP Motorsports
Old 03-27-2011, 08:27 PM   #1
egad09
egad09's Avatar
Drives: 2010 CGM 1SS Camaro
HELP! ... Lost a cap in engine bay!
HELP!! lol.
So i was in the engine bay and was cleaning up everything and noticed the brake reservior was a leaking a bit it seamed so i took the cap off to clean everything up. Cleaned off the cap and put on the side of engine bay where the hood seals. cleaned up the reservor body and put the towel on the side of car (i know not smart.) Problem comes is i put the towel on the cap so when i picked up the towel it SLID DOWN INTO THE ENGINE BAY! Straight down behind the strut tower and into the only hole it fits in ...
pics below of location im talking about ...
the hole under the AAC2 sticker ...anyway to get it out?!?!?!!!!!!!!
tried reaching down into there and found out to things ... 1) its hot in there after driving around. and 2) my hands to big :(
alternate way to retrieve it?
egad09 is offline   Reply With Quote
Old 03-27-2011, 08:56 PM   #2
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
I can't tell from the photo, but if you can see it, even if you can't, perhaps you can use one of those "reach tools". You'll need the "claw" type as shown, not a grabber type. I have a couple of these things and they have saved me from a lot of grief more than once. Good luck.
Alfie
alfie43 is offline   Reply With Quote
Old 03-27-2011, 09:02 PM   #3
egad09
egad09's Avatar
cant see it, cant feel it, dont know how far it went ... theres a hole in the hole (if that makes sense)
Old 03-27-2011, 10:10 PM   #4
RSokie
Proud owner of Litho #195
RSokie's Avatar
Drives: 2011 CGM 2LT/RS
Get like a dowl rod with some duct tape on the end and it will stick to it and pull it up, or even a bent metal hanger.
Old 03-27-2011, 10:13 PM   #5
IROCanSS
Drives: 89 IROC 350
Go get a new one... its gone. I see where it fell and its in that area that you'll spend too much time trying to fish it out. Call the dealer tomorrow.
There is a TSB about them leaking so you need a new one anyhow.
I noticed you said you were wiping off the resivior bc is was leaking... it shouldn't be. Time for a trip to the dealer. They should have them in stock as its a commonly replaced item.
Old 03-27-2011, 10:18 PM   #6
mrh923
mrh923's Avatar
Drives: 2011 Camaro 1SS/M6 Cyber Gray Met.
Yeah I'd suggest a pair of mechanical fingers to fish around in there. Bet you won't do that again!
2011 1SS/LS3 M6--Vararam CAI-Corsa catback-Dynatech LTs-RX Catch Can-Vmax ported TB-Eibach Springs-Night Fury Camshaft- 486RWHP/458 TQ
mrh923 is offline   Reply With Quote
Old 03-28-2011, 09:52 AM   #7
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
You're going to need a new cap anyway since it sounds like you have (had) one of the leaky caps. I did too, and got a new cap under warranty (but it can't cost too much). No leaks with the new cap.
Old 03-28-2011, 10:01 AM   #8
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
I had a similar situation with a bolt. Took off the front tire and the wheel trim liner. Was then able to manipulate it back up thru the hole. Good luck man...
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 03-28-2011, 10:14 AM   #9
Lazerbrainz2k3
Drives: 2017 Camaro 2SS - M6, NPP, MRC
I lost the cap to a liter of oil through the hole for the hood release once, down into the sealed front fascia. Let me tell you what a joy that was, especially squeezing my not-small hand through a hole in the fascia and then having to pull it out again with the cap. I'm surprised I had any skin left after that one - as it was I had my hand glazed with neosporin and wrapped in gauze for a couple days afterwards, but I got that cap out!
Lazerbrainz2k3 is offline   Reply With Quote
Old 03-28-2011, 10:23 AM   #10
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
A few things to note if you are going to get a new cap...
ONE: ( you probably know this) dont drive it with the cap off
TWO: put something over the reservoir for now to keep junk and moisture from getting in there
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Old 03-28-2011, 10:36 AM   #11
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
http://www.amazon.com/gp/product/B00...G0BAD6Q9EKADBH
One of these ^^^ to see if you can spot it and then a bendable wire with duct tape to retrieve.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-28-2011, 03:35 PM   #12
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
a blow torch and a cutting wheel should get it out.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-28-2011, 07:59 PM   #13
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
I dropped a bolt in that hole...took loose inner fenderwell and retrieved it..only way to do it...... even tried claw..& magnet..NO GO
Alfieboy is offline   Reply With Quote
Old 03-28-2011, 08:06 PM   #14
gatorlover
gatorlover's Avatar
Drives: 2013 AGM 1SS/RS 1LE
wire coat hanger
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced)
gatorlover is offline   Reply With Quote
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 01:58 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
