12-01-2010, 09:40 AM | #1 |
Drives: '11 2SS/RS RJT M6 Join Date: Oct 2010
Long Term Durability of Paint Chip Repairs
Hi all,
I'm looking at getting a paint chip repair system. I've been comparing Langka vs. Dr. Colorchip. Dr. Colorchip looks much easier to use but I would believe that Langka's long term durability is greater because it uses factory paint that requires 24 hours to cure vs Dr. Colorchip's 5 minute flash cured paint. Anyone have any long term issues with Dr. Colorchip or Langka? |
12-01-2010, 11:17 AM | #2 |
Drives: 2011 IBM Camaro 2LT Join Date: Jul 2010
used langka on a small chip about 2 months ago..so far no problem!!
12-01-2010, 11:56 AM | #3 |
Used Dr. Colorchip in September, no problems.
12-01-2010, 01:06 PM | #4 |
Winners find a way
Drives: 2010 2LT/RS M6 Join Date: Jun 2010
used both, no issues with either...... DRC is much easier IMO
I've used the langka system to "cleanup" blobs left by other folks' messy attempts. The paint used by DRC is no less quality than factory and requires the same amount of time to fully cure before waxing. IMO, you need to let the DRC dry for an hour, your factory paint kit will flash dry in 5 minutes as well, just don't try to run anything over it.... |
12-01-2010, 03:15 PM | #5 | |
Thanks for the responses.
12-01-2010, 04:00 PM | #6 |
Drives: The shiny ones. Join Date: Mar 2010
I'd say as long as you give it MORE than ample drying time and then make sure to lay down a good coat of wax or sealant either is going to last a long time.
12-01-2010, 06:27 PM | #7 | |
Winners find a way
Yeah, you COULD do it with only 5 minutes, but you won't get a good "fill", They recommend up to 2 hrs wait time. As for the paint, it may have something added that helps the activator. The most important part of any touch up is to make sure the area is clean and wax free before filling. |
Similar Threads | ||||
NEED opinions! About paint chip repair. | zlwebb | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 35 | 01-18-2012 09:37 PM |
Paint your own stripes? | blackZbandit | Cosmetics and Lighting Modification Discussions | 44 | 09-18-2011 09:22 AM |
GM not honoring my Camaro paint warranty; paint cracking and peeling all over the car | jackr67 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 132 | 08-03-2010 09:50 AM |
Gill Paint Chips | MMaglione | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 83 | 05-03-2010 05:35 PM |
Help with paint chip | menendez1293 | 5th Gen Camaro SS LS LT General Discussions | 2 | 04-22-2010 06:04 PM |
