09-23-2019, 05:50 PM | #1 |
Look Ma Im A Music Artist
Drives: 2017 Camaro RS Join Date: Aug 2008
Flashing engine light??
Hello ladies and gents, so I have a perplexing one for ya. While on the highway in sports & auto manual mode, I was doing a quite “spirited” drive when towards the upper range of my RPM, the engine light of my 2017 RS started to flash. I slowed back down and it stayed flashing for about a min or two then shut off. The car seemed fine besides a slight delay in throttle response which was temp. and for the fact that cruise control wasn’t available anymore.
Anyone have any idea as to what happened? The vehicle is stock besides straight pipes going from the axle back. Any help would be appreciated |
09-23-2019, 05:56 PM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
flashing CEL usually indicates a Misfire condition.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-23-2019, 06:06 PM | #3 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Mine did the same thing when I pegged red line. I believe it's GMs way of stashing codes in memory when you redline your car. This code will remain stored and if something ever happens and you need work the first thing they do while performing a walk around is check your codes.
09-23-2019, 08:55 PM | #4 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Incorrect. The ECM can only store about 10 seconds of data and even that data is hard to get to as it is in the crash box. A flashing check engine light is the signal of a misfire being detected. It will have code P0300 stored and if the cylinder that the misfire was detected in is known it will have P0301, 02, 03 or so own for the cylinder with the misfire.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-24-2019, 10:08 AM | #5 | |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
I would get a code scanner and check for latent/pending codes. Your issues with throttle response, cruise, etc. are related to "limp mode," which is automatically present with a flashing CEL. |
09-24-2019, 10:17 AM | #6 |
Drives: 2016 Summit White Camaro LT2 RS Join Date: Jun 2016
I had this happen about 6 months in on my 2016. Similar situation, was on interstate, pulled into fast last to get around traffic and floored it. Flashing light that then went off. Happened another time when I pulled out and got on it a week or two later. Then CEL came on and wouldn't go off. Turned out to be something got bent on cylinder one that affected AFM and was causing a rich or lean condition (can't remember now). I should have tried the lemon law because it took them 4 or 5 different tries to finally get it right. They replaced O2 sensors, something in the exhaust, all of the injectors before figuring it out.
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
09-24-2019, 11:06 AM | #7 | |
2016 NFG 1SS A8
09-24-2019, 12:00 PM | #8 |
For some reason I want to say rocker arm...
09-24-2019, 12:10 PM | #9 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
It couldn't be if he has the RS. Those don't have pushrods.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
05-03-2021, 02:45 PM | #10 |
j1ss
Drives: '21 2SS 1LE Join Date: Dec 2019
What happened with this?
