Old 08-31-2013, 09:18 AM   #71
Casper954
Casper954's Avatar
Drives: 2010 Camaro 2SS
damm have a set waiting to be put on, but probably going to be doing this myself now. thamk you!
Appearance: Blacked out tail lights, Oracle Plasma fogs, SLP Carbon Fiber splitter, Carbon Fiber Hash Marks, Carbon Fiber ZL1 hood, 20" Giovanna Kilis rims, Eibach lowering springs
Performance: Straight-piped magnaflow exhaust, K&N intake
Casper954 is offline   Reply With Quote
Old 09-02-2013, 12:31 PM   #72
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
So did anybody change brake fluid and if so did you drain all of the old out while the lines were off or did you put everything on and than bleed the old fluid out?
CamaroLS is offline   Reply With Quote
Old 09-02-2013, 02:21 PM   #73
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I did. They used a pump to take the old out and then bled in with the new.
[B]
Old 09-02-2013, 02:25 PM   #74
CamaroLS
CamaroLS's Avatar
What fluid did you go with?
Old 09-04-2013, 04:11 PM   #75
CamaroLS
CamaroLS's Avatar
Where is everybody getting the copper crush washers for your brake lines from?
Old 09-04-2013, 04:30 PM   #76
intensifi
Drives: '12 2LT Convertible
New brake line kits seems to come with them.
You can also buy them at the dealer. I think they are $1.25 a piece MSRP.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 09-04-2013, 06:54 PM   #77
CamaroDreams07
Drives: Slow V6
Ate Super blue
[B]
Old 09-05-2013, 08:13 AM   #78
cireisa
Drives: 2010 Camaro V6
Hi there,
Just curious if there's someone interested in buying a full kit of Brembos (calipers+rotors) used for 22k miles. The rotors are Brembo Performance drilled (last two pics) with only 8k on them, don't know the part #.So, to be clear the rotors what you'll get are drilled and shown in the last two pictures.I have the calipers painted yellow ,but they'll need to be repainted because they are dirty.The first image is since I installed them, now they look , let's say not that clean anymore.
I bought these new and installed them on my V6 and they work PERFECT, no rebuild necessary, just bolt them on and enjoy.
PM me if interested.
Thanks
cireisa is offline   Reply With Quote
Old 09-08-2013, 05:19 PM   #79
CamaroLS
CamaroLS's Avatar
Ok, after cutting the shield in the back for the SS rotors to fit instead of replacing it with the SS shield do you get a lot more brake dust on your wheels after the upgrade that you have noticed?
Old 09-08-2013, 06:41 PM   #80
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Yes, unfortunately you will get a bit more brake dust because of cutting the shields.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 09-08-2013, 07:46 PM   #81
CamaroLS
CamaroLS's Avatar
I thought so!! How hard and how much work is it to change to the SS shields?
Old 09-08-2013, 08:21 PM   #82
CamaroDreams07
Drives: Slow V6
A shit ton.
Sent from my One using Tapatalk 2
[B]
Old 09-09-2013, 12:36 AM   #83
intensifi
According to the ZL1 brake upgrade kit instructions (I have a copy) it's a 1.5 hour job to install the rear brembo brakes and replace the dust shields with the SS ones.
Basically you have to remove the e brake on both sides, change the shields then reinstall the e brakes. Some on here have said you have to pull the axles. According the the GM instructions you do not.
Old 09-09-2013, 09:47 AM   #84
nak3dsnake
nak3dsnake's Avatar
A shit ton.
What they said. Its a lot of work to change two dust shields. You don't have to pull the axles but you do have to remove the rear hubs.
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 12:40 PM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 07:23 PM
What's written on the brembo brakes FUTURE TOP DOG OWNER 5th Gen Camaro SS LS LT General Discussions 19 09-19-2008 08:11 PM
Brembo brakes question topgun1 Wheels and Tires Talk Sponsored by The Tire Rack 20 09-04-2008 10:34 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 12:12 AM
