01-14-2017, 05:57 PM | #1 |
Drives: 2015 camaro ss Join Date: May 2016
Oil pan help!
In the process of my cam on an l99 camaro. Got all the oil pan bolts but one. It's hard to get to because of a metal brace in the way. Should I pull the motor instead? Any ideas?
01-15-2017, 08:50 AM | #2 |
old school chevy rodder
you use adjustable head tools to get in the tight spots, and improvise other than that pulling the engine is a whole can of worms you think one bolt is hard.... You got a lift to drop the cradle.....with engine and trans as one.... because out the hood is old school bush league for a Camaro and tight so not a good old v-8 way with all the problems.....you could loosen up the engine a little and get some extra space to drop the pan there have been posts years ago with pics I am sure about the PITA people go through doing a pump swap/timing chain in their Camaro with the engine in place squeezing things in and worrying about the O-ring and pick up tube placement.... I would check the DIY section etc someone knows the name of the exact tool name you need to squeeze in there.. and if your doing it someone has done it before... Good Luck.
01-15-2017, 08:56 AM | #3 |
'It's an experiment'
Robertway did a diy. Look for that. Not sure if a 2015 is different. I did the ss1 on my l99. My build thread has the details.
http://www.camaro5.com/forums/showth...=385577&page=5 Don't have to drop the pan to do the cam Starts on post 68
747 RWHP 794 RWTQ
01-15-2017, 11:05 AM | #4 | |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
01-15-2017, 11:37 AM | #5 |
BTW, the stickys have a list for you, but here is the DIY with videos on dropping the pan and doing the cam install VVT is a bit different and I've covered some of that in mine but Robertways is the best DIY I've seen:
http://www.camaro5.com/forums/showthread.php?t=125123 -Don
747 RWHP 794 RWTQ
01-16-2017, 11:02 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
Its shotty and tuff..dont skip the rags in case you drop the bolts (you surely will). Take your time, take pictures, read read read and re read. Watch videos too.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
01-16-2017, 11:04 PM | #7 |
I made some comments and advice page after the cam swap. You can look for it in my older post history. Take your time, get the right tool. My flexible wrench was a life saver on this, be sure its a 'thin' wrench too like snap on or other thin model. Worth a buy just for it.
13' 1LE
01-17-2017, 12:10 AM | #8 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Yup. Don't skip the rags. I have the pickup tube bolt living in my oil pan because I skipped it. I figure I'll just get it out later and got another bolt. I got the cross member modified to be bolt on so I can pull the pan without having to pull out the block now.
