06-24-2014, 10:20 AM | #1 |
Drives: 2018 SS 1LE Hyper Blue Join Date: Mar 2011
squeeky brakes...WTF
Ok so this is my second 5th gen...first was an 11' 1LT RS, now a 13' 1LE....and I am not sure why but my brakes squeek when breaking from a mid teen speed..i have heard it as well from freeway slowdowns too...any one have this annoying squeek? It drives me nuts in my work parking garage...I just do get why with 2 5th gens..and they both had squeeky brakes...
06-24-2014, 10:25 AM | #2 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Ours does it some too. I meant to check the brake pad thickness when I had new tires put on it a few weekends ago, but missed the opportunity to check the fronts. The backs looked great. It can be annoying.
06-24-2014, 10:37 AM | #3 |
Drives: 2014 2SS L99 Join Date: Mar 2014
Sometimes if the rotors develop a thin layer of rust ,once the brakes are applied this residue can imbed into the pads and glaze them. May have to remove calipers and lightly sand pad surfaces. Another cause is warped rotors.
06-24-2014, 10:44 AM | #4 |
36.58625, -121.7568
First I've heard of this...
06-24-2014, 10:55 AM | #5 |
Thunderclap
Drives: 2010 Camaro SS IBM (LS3) Join Date: Feb 2012
This is usually my thought process when it comes to squeaky brakes:
1. Check rotors, if they are rusted then clean them or replace as grooves (if a penny is the same width as the groove) develop on the outside. 2. Check pad life. Notice how far the pads are from the wear bar. 3. If 1 and 2 are fine, then take the brake pads out and apply brake lube to the contact points (on the back). This is what fixed my squeaky brakes. Using brake cleaner on calipers help too of course by getting all that old residue off.
MODS
- Magnaflow Catback 16580 exhaust - K&N CAI - 20% tint - Spyder CCFL Halo Projector Headlights - Barton Pistol Grip Shifter - Bumblebee custom stripe kit |
06-24-2014, 11:04 AM | #6 |
I figured with 6k miles on it and not really "racing it" hard braking and all..that pad wear shouldnt be a concern...Ill take the wheels off this weekend and lube the pads..and clean the calipers..see if that helps..Thanks for the replies..
06-24-2014, 11:10 AM | #7 | |
Future Mopar Owner
Drives: 2011, 2SS/RS, Synergy Join Date: Aug 2012
Really?
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold You will be missed but you are in good hands! 2019 Challenger Hellcat B5, Redeye, Widebody |
06-24-2014, 11:18 AM | #8 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
Put grease on top and bottom of pad backing plate where it slides on the aluminum caliper.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
06-24-2014, 11:19 AM | #9 |
Performance pads tend to squeel more, nothing out of the ordinary there.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
06-24-2014, 11:24 AM | #10 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
Mine have squeaked since break-in. Not worth fighting, but I hate it just the same.
Bye bye, Bumblebee!
06-24-2014, 12:28 PM | #11 |
The comments concerning rust are interesting. I had not heard them before, and since the rotors seem to develop surface rust after a good rain or a car washing (at least down here in the humid south east), I wonder if this is the problem.
06-24-2014, 12:47 PM | #12 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
So far mine has not squeaked .If it does I'll just turn up the XM and ignore it .Like when your wife bitches at you ,you just tune it out.
OLD GUY FLYING FAST AND LOW
06-25-2014, 09:38 AM | #13 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I live in dry CA, and my brakes squeak sometimes and not other times. It's annoying but helps that I have NPP with the fuse pulled and no sound deadening in the trunk...
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
06-25-2014, 01:09 PM | #14 |
Drives: Piercer Join Date: Mar 2014
My old 2012 2LS had a TSB for it when I mentioned it to the techs. (for excessive brake noise) Solution was "deal with it!"... Well, if you complained enough they would give ya new pads and even rotors if you take your complainin' that far, but I never bothered. Traded in that car like nine months later anyway. My 2014 2LS has no such issues. So, who knows. Part suppliers change probably on a monthly basis for GM. Who knows what year, model, revision is getting what shoddy parts.
