Old 12-17-2015, 03:43 AM   #1
l008com
l008com's Avatar
Drives: 2013 1LT Crystal Red/Beige Manual
Question RS Headlight Compatibility
I've got a set of RS HID headlights I bought (off this forum) many years ago for my 2010 Camaro. I then upgraded to a 2013 Camaro and swapped the '10 RS lights in no problem. So I assume the lights are also comparable with 2011 and 2012 Camaros as well? What about 2014 and 2015? The bumpers of the '14 and '15 look a little different but I can't tell from photos if the lights are actually different. I ask because my lease is up soon so I'm getting ready to sell the lights. I know that on all non-RS cars, you will need a custom wiring harness to properly use the lights.
Not RS:
l008com is offline   Reply With Quote
Old 12-17-2015, 06:11 PM   #2
ron123
ron123's Avatar
Drives: 2014 2SS/RS
2014-15 RS headlights are way different in Halo shape - and to the right of the Halo there is a rectangle with the word "Camaro" in it - does not show well in this picture
ron123 is offline   Reply With Quote
Old 12-19-2015, 09:28 PM   #3
Mean Green Z28
Drives: 2010 2SS
Let me know when you take them off and are ready to sell, may be interested
Sent from my SAMSUNG-SM-G900A using Tapatalk
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 12-20-2015, 04:42 PM   #4
l008com
l008com's Avatar
I PM'd you.
Old 12-26-2015, 04:20 AM   #5
real_69'SS
real_69'SS's Avatar
Drives: 1969 SS 396
RS headlight swap into non RS
I also have a 2013 that I want to put RS headlights in. Some of the places I have been looking at say that the headlights are specifically for non-RS cars. I was wondering what he difference is and if and or why it isn't a straight across swap.
"There's no replacement for displacement"
real_69'SS is offline   Reply With Quote
Old 12-26-2015, 04:31 AM   #6
l008com
l008com's Avatar
The RS and non-RS lights physically fit in all cars across the compatible years. The issue is the wire connectors are a little different. This is because the non-RS car uses low voltage low beams (or is it high beams) for daytime running lights. The RS lights are HID so you can't give them low voltage, so they use the fog lights as DRL's instead. So to use these lights in a non-RS car, you need little adapter harnesses that convert between 3 and 4 pin connectors. And they also need relays in them so when you send low voltage to the low beams, it ups it to full voltage. I have these harnesses too but the relays no longer work, so I would have to turn off the automatic lights every time I got in the car. It's a little bit of a pain but it's totally worth it. The light output difference between HID and non-HID is gigantic.
Old 12-26-2015, 04:17 PM   #7
GetYouOne
Drives: 2012 2SS/RS
Just buy a non RS to RS Harness from Gen5DIY its all plug and play. I have a set of new 10-13 RS Lights for sale if anyone is interested.
GetYouOne is offline   Reply With Quote
Old 12-27-2015, 12:54 AM   #8
l008com
l008com's Avatar
Do you have a link to these harnesses because i'm on their website and i can't find it at all.
Old 12-28-2015, 12:46 AM   #9
real_69'SS
real_69'SS's Avatar
Drives: 1969 SS 396
Thanks !
