01-03-2015, 10:05 PM | #1 |
Drives: Zelda--A 2014 Summit White ZL1 Join Date: Feb 2014
Hit the wall: My ZL1 at Laguna Seca
http://youtu.be/Ov-FO2PFc9k
My tires were too cold on the first run of the day. (I love these tires when it is warm, but they suck when it is cold.) It was in the high 40s or low 50s during the first run. I barely hit the accelerator coming out of turn 10, and the tires just let loose. Scared the hell out of me, even though I just barely hit the wall. Not sure of the cost of the damage, but it is no more than a fender bender. If you only care about the accident, start watching around 2:00. |
01-03-2015, 10:10 PM | #2 |
So Cold!
Drives: Summit White 2015 2SS Join Date: Feb 2013
Glad you are okay!
01-03-2015, 10:13 PM | #3 |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
That sucks. Looked like good run but a soft hit. What data recorder are you using?
Thanks for sharing.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
01-03-2015, 10:15 PM | #4 |
Drives: 2010 2SS Join Date: Sep 2012
hot damn you got lucky.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
01-03-2015, 10:26 PM | #5 |
I definitely did. It was a soft hit, but it could have easily been much worse. I finished off the rest of the day, but was definitely nervous. What I learned more than anything else is: 1. These tires suck when cold; and 2. The power of this car is actually pretty damn dangerous; and 3. Don't put it in PTM 5 until the tires warm up. I did forget to mention that I usually run in PTM 5 for the Race setting on the shocks. This, however, turns off almost all of the traction control. Out of habit, I put it in 5 when I started. BIG MISTAKE. I ran in PTM 3 and 4 for most of the rest of the day. However, Sport suspension is just not stiff enough for the track. There was a 1LE there as well, and he was all over the track. Simply don't take these tires to the track if it is under 60 degrees F. Craig |
01-03-2015, 10:29 PM | #6 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
If it's fender and bumper damage it could be $2500 and up. I had my car at a dealership and they hit it on the opposite front corner. New fender and bumper repair, blend hood and driver door. $2500 for that. Oh yea I learned about PTM5 at the first C5 Fest in Indy. It will definitely come around on you.
01-03-2015, 10:29 PM | #7 | |
It usually works great, but notice that the time wasn't updating. Craig |
01-03-2015, 10:31 PM | #8 | |
Craig |
01-03-2015, 10:33 PM | #9 |
C'mon- really?
Thanks Craig. Glad that you and your car are ok. That was great advice about PTM 5 if the tires and track are cold.
Steve
01-03-2015, 10:34 PM | #10 | |
Craig |
01-03-2015, 10:35 PM | #11 |
Drives: 2015 ZL1 Join Date: Dec 2014
I have owned and tracked a range of cars over the years; Lotus Elise (w major mods), STi, F430, F355, and more and I have never had a car come with OEM tires that were so marginal in real world conditions. I think the benefits gained under the ideal conditions are not worth the trade-off for the limitations the rest of the time, more so true if you use the car as a daily driver as I do. I replaced mine with sottozeros for the winter but I think I will go with Pilot Sports, I have pushed those on the street and track in all temperature ranges with good results.
Love the car, hate the tires. |
01-03-2015, 10:56 PM | #12 |
Go fast, please.
Any pictures of the damage?
01-03-2015, 11:07 PM | #13 |
Flying da helicopter
That sucks, but thankfully you are ok. That looks like a lot of fun. I'd like to run a road course one day. Stay safe man!
01-03-2015, 11:16 PM | #14 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Sorry about the mishap. The hit didn't sound bad, but do not take short cuts in the repairs. The fix will be what it will be.
I also noticed that you weren't really going that fast. It didn't seem like a tight turn so I'm surprised that the tires let go like that. 60 d weather is like Spring, so to hear and see this is discouraging.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
