01-09-2012, 08:40 AM | #1 |
Drives: 2013 Cyber Gray Metallic Chevy Volt Join Date: Dec 2011
My car doesnt know me anymore. help!
The key on my FOB wont start the car,. Either will the back up key. The FOB does unlock the doors. Radio can be turned on, nothing else works.
The key wont even turn. Im stuck at work 45 miles from home. :( |
01-09-2012, 09:40 AM | #2 |
Drives: GM Vehicles Join Date: Jun 2010
IowaGuy, is there a local dealer you could call that would perform this work for you? You may also be able to get assistance from your roadside assistance number as well. They can be reached at 800-243-8971. I hope this helps you. Let us know how this all works out.
Jeff Morris, Chevrolet Customer Service |
01-09-2012, 09:42 AM | #3 |
Drives: 2013 2ss/rs A6 yellow !!!!! Join Date: Nov 2011
Do u have any tools with u? If so id try and disconect the battery in the trunk and wait a few maybe 15 to 20 min then try and relearn the keyfobs if it doesnt start working. I cant remember the relearn process if someone else wants too chime in.....
01-09-2012, 09:51 AM | #4 |
Drives: 2011 Black SS M6 Join Date: Oct 2010
I bet the steering wheel is turned and the ignition is locked. Tilt the steering wheel to the left or right and then while you have the wheel turned a bit, try turning the key.
01-09-2012, 10:28 AM | #5 |
knows 2 facts about ducks
This could possibly be the problem.
01-09-2012, 11:02 AM | #6 |
You rock, TheHorse13. I'm vroom vrooming again.
01-09-2012, 12:13 PM | #7 |
Yeah i read that wrong.....mine did that too me the other day i just had too take the pressure off the steering wheel.... Kinda freaked me out too
01-09-2012, 04:20 PM | #8 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
Why 2 threads on the same topic???
http://www.camaro5.com/forums/showthread.php?t=194441
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
Similar Threads | ||||
PQs Camaro [COTW 9/20/10] | PQ | Member Car Journals | 5664 | 07-28-2020 12:10 AM |
HOW TO: Get rid of UNDERSTEER on C5 member Buffnshine's Camaro | PfadtRacing | Suspension / Chassis / Brakes | 6 | 08-31-2011 09:51 AM |
Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 05:20 PM |
Why you can't buy a new car directly from the manufacturer | scotchsride09 | Off-topic Discussions | 13 | 02-14-2009 05:15 PM |
