09-20-2011, 04:24 PM | #1 |
Camaro 5 Muscle
Which is the best oil for the V8?
I need to go get an oil change tomorrow. Im running at 6269 miles. Which oil should I put in in?
Thanks.
TSW Donington 22" Matte Black / Corsa Cat-Back Exhaust / Kooks Signature Stepped Headers 1 3/4" - 1 7/8" / High Flow Cats / Custom Tune / CAI Cold Air Intake / BMR 1" Lowering Springs / VMax Ported Throttle Body / Heritage Grill / Havoc Rear Diffuser
09-20-2011, 05:13 PM | #2 |
i like to go fast
Drives: 2011 SS Join Date: Sep 2010
For a top oil that meets GM suggested requirements, I recommend Pennzoil Ultra 5w30. You can find it in 5 quart jugs at your local Walmart. However, other oils may work just as well.
09-21-2011, 12:20 PM | #3 |
Camaro4ever
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro Join Date: Jul 2010
GM says Mobil-1 5-30W synthetic, they designed it why question this?
09-21-2011, 12:30 PM | #4 |
Boosted Moderator
Unless you're running a built motor with huge stresses, I would stay with the mobile 1. The manufacturer uses it, and tested the motor with it...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
09-21-2011, 12:43 PM | #5 |
GM approved oils
Attached listing of all the approved oils
"Never argue with a fool, onlookers may not be able to tell the difference." - Mark Twain "Never argue with an idiot, they drag you down to their level and beat you with experience" - Unknown |
09-21-2011, 12:49 PM | #6 |
Drives: '09 Honda Civic LX Join Date: Jun 2009
Pennzoil Ultra.
And the reason why GM recommends mobil-1 is because mobil-1 payed for them to recommend it.
Saving up for a camaro.
Dream camaro is either a 1/2SS with RS, black with red stripes, or red with white stripes. No rice with my order. |
09-21-2011, 12:58 PM | #7 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Similar Threads | ||||
2010 Camaro V6 Oil and Oil Filter Change | azamazonqueen | Camaro DIY & HOW-TO instructions & discussions | 116 | 03-19-2017 01:36 PM |
Need Mechanics Help with Oil Pressure Issue on 1999 3.8 Camaro | Solocus | 4th Generation Camaros | 8 | 05-06-2011 09:49 AM |
Gas prices WILL go lower... | ga0358 | General Automotive + Other Cars Discussion | 113 | 05-02-2011 01:16 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
