09-16-2012, 04:47 PM | #1 |
How Wide?
Aright so how wide of a rim and tire combo can you run on the rears without having to do any modifications. I run 315's with know problems but how much wider of a rear tire and rim could I run? I have been thinking about get new rims and I want to go as wide as possible on the rears.
I tried searching this but couldn't find anything.
Mods: "Cam Only"
09-16-2012, 05:03 PM | #2 |
Drives: 11 Seconds or Faster Join Date: May 2012
I think SUX2BU ran a 335 on an 18" rim, he tends to be the guy to ask on wheel fitments and offsets, he measured it all not to long ago.
09-19-2012, 12:38 AM | #3 |
So anyone else? Is 335's the biggest you can run?
Mods: "Cam Only"
09-19-2012, 05:21 AM | #4 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
315's if you want them inside the wheel wells
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
09-19-2012, 08:36 AM | #5 |
Drives: 2010 Camaro SS, 2014 Z28 Join Date: Jan 2012
Here's what 335's on an 18 wheel for track use looks like. Way outside the wheel wells. But they work.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
09-19-2012, 04:49 PM | #6 |
Drives: Camaro SS Join Date: Mar 2011
What size wheel are you looking to run? In 20" a 20x11 on a 315 with the Scarallo Drift-R fits absolutely perfect. We havent seen another fitment that fits as nice by another wheel company.
Many of the other combos that people are running in 18" and such are also a shorter over-all diameter. So, the question is, what exactly are you looking for? |
09-19-2012, 05:29 PM | #7 |
Alright so its looking like 315's are the best fit. I didn't think about them sticking way outside the wheel wells.
Mods: "Cam Only"
09-19-2012, 05:49 PM | #8 |
metzler 360
09-19-2012, 05:58 PM | #9 |
Maybe you should look a little harder. I can assure you that my CCW's which are 10" front w/275/40's and 11.5" rear with either a 305/35 or 315/35 fit just as good or better than the wheels you are making such claims about. I have pics with a straight edge if you would like to compare? We could compare weights as well.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint Last edited by FEN; 09-19-2012 at 06:18 PM. |
09-20-2012, 07:40 PM | #10 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
I'm more concerned about front traction. The Camaro way understeers and maximizing front grip is the key to speed on a slalom course.
I'm currently working with Forgeline to fit 19x11's up front to run 315s. Mind you, fitment depends on suspension components.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
09-20-2012, 08:14 PM | #11 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
_________________________
2012 IMB CAMARO SS |
