Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southwest
Old 07-17-2017, 08:58 PM   #1
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
Best E85 in Tucson and Phoenix
Wondering if anyone has done the legwork and tested the e85 % around Phoenix and Tucson. A Facebook post showed the shell in Sahuarita off exit 75 I-19 (south of Tucson) has the best e85 in the area.
What about Phoenix?
With No Fly Zone coming back to Gila Bend in October, where's the best corn in town?
Sent from my XT1585 using Tapatalk
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 07-23-2017, 05:03 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
The only one I'm showing operational in the south part of the county is a Valero in the 4300 block of Chandler Blvd in Awatukee (Phx), but one site says it may be non-operational. There are several others, but they are further north in Phx and Scottsdale. If you're looking for something closer to the I-10/I-8 junction I think you may be out of luck. Didn't see anything in Casa Grande.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 07-23-2017, 05:46 PM   #3
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
If you are doing the No Fly Zone... Torco will be there with anything you need
Just sayin'!!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 08-01-2017, 11:44 AM   #4
Dirtdog
Dirtdog's Avatar
Just sayin'!!
I'll def be putting in an preorder before I get up there!
Old 08-01-2017, 11:45 AM   #5
Dirtdog
Dirtdog's Avatar
the "Corner Store" in Casa grande has e85. next time I go through there ill test the %. bought the tester on amazon.
