05-23-2011, 10:12 AM | #1 |
Drives: 2011 2SS/RS ord 7-7-10 home8-24-10 Join Date: Jul 2010
'11 2SS automatic transmission fluid change
If anyone is interested, I changed the Dexron VI out on my baby this weekend and am happy to share the experience. I wanted to switch to Amsoil low viscosity fluid. I have access to a lift and imo that makes this job a lot simpler. I first removed the 15mm drain plug from the rear of the pan and I'd say 2-3 quarts drained out. From there, the 10 mm bolts come out easily and the reuseable pan gasket separated cleanly. I let the remaining fluid drip while I wiped the magnet and pan clean. More stuff on the magnet than I would like to have seen. Replaced the pan, torqued the pan bolts to 80 in/lbs, and used a Mighty Vac to push about 6.5 quarts of new fluid back into the bottom drain bolt. I started the engine and while holdng the brake went through each range for several seconds. I used the trans temp guage to tell when it was warm enough (between 86-122' F) to check the level. You check level by removing the bolt in the pan again with the engine on and adding fluid until it just runs out. Reinstall bolt to 18 ft/lbs. Wipe excess, check for pan leaks and done.
I will say the shift characteristics seem crisper, especially 1-2 upshift with paddles under load. Hope this helps. |
05-23-2011, 12:58 PM | #2 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Wow, this trans does not have a dipstick?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
05-23-2011, 01:45 PM | #3 |
Drives: 2013 1LE on order TPW 12/31 Join Date: Jan 2010
no sir, no dipsticks on these cars
05-23-2011, 02:17 PM | #4 |
WTF? What kind of crap is that? Gm
05-27-2011, 06:34 PM | #5 |
Drives: 1SS Camaro Join Date: Sep 2010
Nice write up... I'm wanting to put royal purple in my l99 transmission, but I'm hesitant due to lack of experience.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
05-27-2011, 08:09 PM | #6 |
I'm not totally useless..
Plus, you have to remember that you are only getting about half of the fluid out unless you drain the TC (ours don't have drains either!), so mixing may not be a good idea...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
07-13-2011, 09:15 PM | #7 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
so how do you completely drain the fluid from it then ?
Did you have to unbolt the pan completely ? or is there a way to pump it out ? |
07-13-2011, 09:58 PM | #8 | |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Nope. Lokar makes one though for the 6L80. Mixing doesn't hurt a thing other than you won't get the full benefits from one fluid or another. Amsoil and DEX6 are fully compatible. |
Similar Threads | ||||
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4242 | 02-17-2014 08:57 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
