Old 03-09-2015, 04:00 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
cam wear is this normal
This is the oem cam with 9000 miles on it. are these lines normal. i cant feel them with my fingernail. there on 2 lobes
JCunningham is offline   Reply With Quote
Old 03-09-2015, 09:13 AM   #2
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
none of my cams have come out looking like that.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-09-2015, 11:52 AM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
I am no expert ,but with only 9000 miles and it being a stock roller cam that looks strange. What kind of oil are you using ? Are you warming the car up to temp B4 romping on it ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-09-2015, 11:59 AM   #4
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
That not oil related wear. You have some bad lifters causing that.
Dimitrim is offline   Reply With Quote
Old 03-09-2015, 01:31 PM   #5
Russell James
Russell James's Avatar
Looks like a chip from something got stuck under the roller. Does the roller have a flat spot.
This is why race blocks and heads get deburred. You don't want any tiny casting chips off the edges falling down on the cam.
Old 03-09-2015, 02:06 PM   #6
Ivan @ Southwest Speed
THIS.
You have some debris in there. If it were a spun lifter it would have torn the camshaft up something fierce.
Get her all cleaned up, swap that stick, and change the oil and filter a couple times.
Good luck sir!
Old 03-09-2015, 03:19 PM   #7
JCunningham
Drives: 2017 2SS M6
this is my stock cam that i pulled out befor i put the Night Fury cam in. GM installed this cam. I will be pulling the nf and changinging lifters.inspecting cam bearings.
Old 03-09-2015, 07:08 PM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Here is a pic of my cam after most likely 5-8 k stock.... I have been cammed since march of 2014 and have about 14.5-15k on my car, the stock cam was in from nov 2012 to mar 2014 and I drive about 5k a year usually..( have made some long road trips and love riding around now....
So no it is not normal (and this pic the cam still has some oil on it), I know you most likely had a problem before you swapped cams with those lines it did not help from most likely foreign objects in oil. I know this has to have Pissed you off, I would gladly give you my stock cam for free J . Good luck, and don't give up on the driven racing oil, TSP now recommends it along with a lot of others, and my cam is still going strong along with my stock oil pump and stock chain, and I know its more radical than the night fury, I use .675 springs and have .639/.623 with 235/239 and 112 lsa.
Old 03-09-2015, 09:14 PM   #9
JCunningham
Drives: 2017 2SS M6
Kip from cam motion sent me a private message on here and I talked to him on the phone today about it. He thinks it was a problem with the junk in the stock cam. He recommended I change the lifter which i have ordered. LS7 lifters and ARP head bolts. GM gaskets. He also said if cam bearing were bad id know it by now.
Old 03-10-2015, 04:09 PM   #10
Guinness2
Guinness2's Avatar
Drives: 14 Camaro 1SS RS 1LE Summit White
I'm not trying to hijack this thread but you are making 500 RWHP cam only on a Mustang dyno ?
2014 1SS/RS 1LE, Summit White
2000 Trans Am
2004 LWB Chevy 2500 Van
Guinness2 is offline   Reply With Quote
Old 03-10-2015, 06:57 PM   #11
christianchevell
I have dual mode. Electric power steering. Stainless power headers with HFC, also a vmax and under drive pulley with CAI and scoop and a .639/.623 lift cam..... and the best tuner I could find who custom mapped my fuel curve and dyno tuned the car. And to put the thread back on course; Hey J: I would get a camera to look in your engine to inspect your bearings...they are easy to rent or even buy now to look inside a engine and inspect...like harbor freight may have one even to check the cam bearings just for giggles, they are just like a long flexible tube.. Good luck! Having a engine eat up the cam from deterioration should in effect send metal into the oil and can damage bearing surfaces amongst other things.
Old 03-10-2015, 07:58 PM   #12
JCunningham
Drives: 2017 2SS M6
the good thing is i never found any metal in the oil and the blackstone report shows everythings normal. So I just recieved everything to do the lifters too. so cam and lifters. I have a mirror i can stick in there but ill look into renting a camera. I dont like returning things. maybe my brother could use a $275 rigid camera.
Old 03-12-2015, 06:07 PM   #13
christianchevell
good luck J you deserve some that's for sure
Old 03-13-2015, 11:49 PM   #14
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
Yeah good luck man!
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned
z3R0fo01 is offline   Reply With Quote
