09-04-2014, 01:56 PM | #1 |
Drives: 2011 SS- Whipple SC, Kooks headers Join Date: Aug 2014
2011 L99 Whipple build
ok, added the Whipple 2.9L on a stock L99, added Kooks 1 7/8 headers and 3'' x pipe same time, Corsa 2 1/2 axle back. Snow water methanol kit (2nozzle)..With Whipples tuning it put down 500rwhp / 506rwtq on a Superflow chassis dyno...Since then got rid of the Corsa tail section (sounded like crap) and custom built a stainless 3'' tail section with custom made mufflers (noise cut in half, slight drone at 60-65mph), also added a Roto Fab Cold air intake. Bought into the tuning at this time as well and dialed it all in using an ECM 1000 laboratory grade lambda sensor..Car sitting at 527rwhp/529rwtq now...
09-04-2014, 03:15 PM | #2 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
What did you use for fuelling?
09-04-2014, 03:57 PM | #3 |
Seems way way way way low. TT l99 cars are doing well over 650rwhp here in Phoenix with no other mods.
You are right down the street from me.
Nick
Corvette Z06 -1200ish rwhp |
09-04-2014, 04:37 PM | #4 |
112 ambient..last week..Let us not forget, testing done on a Superflow not a "pumped up" Dynojet
09-04-2014, 04:42 PM | #5 |
Too much is never enough!
I would have thought you gained more.
09-04-2014, 06:57 PM | #6 |
Still seems low. Had plenty of blower/turbo l99 cars on dynojet and dynapak and unless the superflow is 15-20% less than something is up.
Nick
09-05-2014, 01:28 PM | #7 |
bring yours over for a free test and lets find out the difference.. this has been a arguing point for far too long, everybody seems to be used to the Dynojet number as a standard
09-05-2014, 01:44 PM | #8 |
Drives: 2011 Camaro 2SS/RS L99 Join Date: Aug 2013
how much for the whipple? Also im assuming you got the AFM tuned out?
Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance |
09-05-2014, 02:47 PM | #9 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
Nice work, pay no attention to him, he jumps in so many threads pumping the turbo kit it really is starting to be ridiculous. He doesn't even on a camaro
09-05-2014, 05:13 PM | #10 |
Driving one right now actually.
I would have to go to a dynojet first to get numbers, but would gladly swing by and have you run my car to see the difference. I only have old dynapak numbers before recent mods.
Nick
09-05-2014, 05:18 PM | #11 |
happy to do it Nick. Call when ready
09-05-2014, 05:22 PM | #12 |
You mount and balance tires? If so I need that done Just got my new tires today.
Feel free to ignore me. I've been doing this so long I'm just use to all these blower cars/etc making 600+ and forget that just out of the box without all stuff like cam/etc they don't do 600 out of the box.
Nick
09-05-2014, 05:59 PM | #13 |
no tire work, we use Rim1 in Phoenix or Performance tire & wheel in mesa
Cam, Springs, LS7 lifters next week |
09-06-2014, 12:46 AM | #14 |
Drives: 2011 CAMARO 2SS RS Join Date: Sep 2013
I would check to see how much boost you are making. Numbers seem a bit off but its possible depending on the temp. My car feels like a beast at night and during the day it can feel like its losing power at times.
2007 GMC stock
2011 CAMARO 2SS RS-kooks long tube/flow-master American Thunder full exhaust, duel electric cutouts, Mcleod RXT, ZL1 3.73 kit, PFADT sway bars, Toe rods, Lowering springs, Trailing arms, solid rear cradle bushings, BMR motor mounts, Stage 7 RPM TR6060, Whipple Supercharger, LPE twin fuel pumps, ID850 injectors, Elite Catch Can, VEI Gauges, Blower Cam LS1 277LCB HR-14, Barton Short Throw Shifter. Widen Stock rims with 315s, Lots more. 615rwhp 530 rwtq on mustang dyno |
