08-20-2014, 11:27 PM | #1 |
Drives: 02 Camaro Join Date: Oct 2012
Street/Strip alignment
Who wants to share their specs?
Thanks |
08-21-2014, 11:14 AM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
0 camber, 1/32" total toe
08-23-2014, 10:10 PM | #3 |
Thanks. I will see where mine is and adjust it to your specs.
10-02-2014, 06:58 PM | #4 |
Drives: 2012 Camaro Ls3 Join Date: Apr 2012
How did you end up liking this alignment? I'm going in for alignment Saturday and was looking for a street/strip setup also. Anybody else care to post theirs?
Dynatech LT headers/Hi-flow cats/Jannetty rough idle blower cam/Full BMR suspension/3" magnaflow catback 442rwhp-410rwtq
10-14-2014, 04:47 PM | #5 |
Drives: 2012 2 SS/RS Join Date: Oct 2014
Can anyone translate the toe in to inches on this? Ended up at -0.30
10-14-2014, 05:47 PM | #6 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
10-14-2014, 05:52 PM | #7 |
Looks bad to me too. Needs to be positive on the toe. Probably wanders around in the rear on grooved roads.
10-14-2014, 05:55 PM | #8 |
The negative is from spec it's actually on the positive side still
10-14-2014, 06:08 PM | #9 |
Still+5
10-15-2014, 08:15 AM | #10 |
What happen? You had the right specs?
10-15-2014, 08:36 AM | #11 |
Zero on the bottom of that machine is dead center of factory specs, the negative numbers are outside of that. The camber is set as close to 90° as possible with the stock adjusters and the toe is at 5°... Just not sure what that equates to in inches... The readings on the machine are deceptive of your not familiar with it.
10-15-2014, 08:55 AM | #12 |
Have you launched it yet to see how it does
10-15-2014, 08:56 AM | #13 |
No, been raining here
10-15-2014, 10:05 AM | #14 |
H-E. What are the right specs. Thanks. I am adding 5 lbs of boos to my SLP ZL560 and I am going to take it to the track Saturday. The best the car has run is 12.7 at Bandimere. Hopefully I make it into the 11's.
