08-22-2014, 06:29 PM | #1 |
Drives: 2012 Camaro Ls3 Join Date: Apr 2012
FI for drag strip?
I've been trying to research how the AGP TT cars have been doing at the strip but can't find much on it. How well do TT's perform at the track with these heavy cars? I've been looking into the AGP kit or into the ECS kits. If anybody cares to pitch in which FI is having the best luck with a stock cube m6 it would help make up my mind
Dynatech LT headers/Hi-flow cats/Jannetty rough idle blower cam/Full BMR suspension/3" magnaflow catback 442rwhp-410rwtq
08-22-2014, 06:41 PM | #2 |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
Depends what your goals are...
Turbo size... how much boost/power you looking for... Do you have suspension work? Etc etc. In general TTs perform extremely well in heavy cars. More so when you have some spray to get them off the line quicker.
2012 CTS-V: Cosmetic Chute. |
08-22-2014, 06:51 PM | #3 |
All the local ones run amazing. Only car I can comment on is Cortney@AGP has a 2010 l99 auto car. TT kit, 11psi, nt05R 305 18" tires and it went 10.8@135 in Tucson with DA around 4000ft. Car is being built with a 416/etc now so should be faster when it goes out. Few other cars running high 10s with just turbo kit/tires/clutch/etc. Doesn't need cam/heads/etc.
Nick
Corvette Z06 -1200ish rwhp |
08-22-2014, 07:04 PM | #4 | |
Your ctsv is badasssssss btw!
08-22-2014, 07:08 PM | #5 | |
08-22-2014, 07:10 PM | #6 |
Amazing. Tons of low end torque, easy to control, drives like stock when wanted. Add some gas and abundant torque/power everywhere. On the auto there was no way to get it to lag since if you gave it enough gas it just downshifted and went. Car made 740+ ft/lbs of torque and had crazy mid range.
Nick
08-22-2014, 08:55 PM | #7 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
If your looking for low 1/4 times with a six speed you will be much quicker with about anything over turbos.There is some nice kits out there, they can put up nice dyno numbers, most will never get a decent 1/4 mile time with them.It is very tuff to make a quick six speed car, tuffer with turbos.
08-22-2014, 09:41 PM | #8 | |
08-22-2014, 10:15 PM | #9 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Just my opinion but you titled the post FI for the drag strip. When drag racing, the first step is getting the car off the line and with a manual it will be a lot easier if your forced induction system has a broad power band. Because if you have tires and suspension dialed in which I'm guessing you do, then the wider the power band the less precise you have to be with the clutch to run a good 60 ft. Positive displacement supercharges give more torque and make it easy for a hack like me to consistently run 1.5 sec 60 ft times with a 4300+ racing weight. That was with 900 ft/lbs of torque at 2400 rpm from a TVS 2300 on a 427 block.
Once you are out of first gear it is all about the peak on the dyno sheet, more power makes more mph. Turbos are the bomb once they get rolling because they just plain make more power. The base turbos in the AGP kit can easily push 1000whp through the stock motor if you are brave enough (or foolish enough) to turn them up. Now that I have been studying turbos I have realized that virtually no one running twin turbos is even close to using all of the boost potential their turbos could make. The crazy 4 cylinder guys are making 1000whp and 30+ pounds of boost on less displacement then we have on one bank, with basically the same turbos we are running for twins. Even the monster centrifugals can't match the peak power available from a good set of twins. If you are a power junkie you will love turbos and you will never build the car to a point that the turbos are not enough. If I was starting from scratch I would start with the twin turbo kit. As you upgrade the rest of the motor you can just turn up the boost you have not even tapped. I started with blowers, I maxed out every horse I could get out of the 1.9 LSA (757whp) and then I went to a 2.3 and spun that as hard as I possibly could (835whp), then I sprayed nitrous on it (1203whp)... I'm mounting turbos right now and though I decided not to remove the blower, I don't think I will need nitrous ever again.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
08-23-2014, 07:28 AM | #10 |
08-23-2014, 06:06 PM | #11 | |
Speed Freak
If I was starting over I'd start with turbos.
08-23-2014, 06:58 PM | #12 |
Drives: ZL1 Camaro Join Date: Feb 2009
Don't have AGP but a similar setup and Matt@FSP installed the entire scavenge system from AGP to my setup, I run consistent mid 10's and drive it a lot, of course I broke a few 6l80's and now Matt installed a 4L80 and looking to boost more, I don't see a lot of turbo cars running at the track, not sure why, but from my experience, TT's need less boost vs other FI setup to run the same numbers at the track.
08-23-2014, 07:55 PM | #13 | |
Speed Freak
Superchargers take crankshaft power to spin. Most of them are turning 300+ revolutions per second and the higher the boost number is, the greater the resistance the supercharger has to turning it. The general rule of thumb is it takes about a 5 horsepower per pound of boost you make in a supercharger. Turbochargers use exhaust gas pressure that is virtually untapped energy to spin them. They do effect overall backpressure and combustion temps but they are much more efficient. So a supercharged car making 10 pounds of boost will have to have roughly 50 more horsepower worth of air and fuel than a turbo car making the same boost. Overall the turbo puts more power to the tires with less strain on the drivetrain. I think your experience with boost numbers is correct.
08-24-2014, 07:56 AM | #14 | |
