11-26-2023, 11:39 AM | #1 |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
Dex VI sux.......
Dex VI is a terrible fluid that induces T/C shudder thru it's hygroscopic defects.
EVERY GM car I own get's the Mobil 1 Blue Label. My new to me 2015 2SS automatic had very lazy shift behavior. Granted, the fluid did have 58k on the clock. After a double drain and refill with the Mobil 1 Blue Label..... It feels SO MUCH BETTER. Like a shift kit was installed? No. But a big improvement in shift quality and strategy. |
11-27-2023, 08:27 AM | #2 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I guess I got lucky and had a good batch. I've never had an issue running the VI. But it's replaceable. Do what you must.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-27-2023, 09:23 AM | #3 |
11-27-2023, 11:26 AM | #4 |
Older Than Dirt
When the TSB came out, I was under the impression that the 2016 and up had the "issues".
I don't recall that issue as a wide-spread problem with the 5th gens. Haven't had any issues in the 2010 with any shudder or shifting issues. At least not yet. Stuff is about thin as water, though, right out of the bottle. So if your transmission isn't spot on with clearances, there could be some issues, I suppose.
11-29-2023, 04:56 AM | #5 | |
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
11-29-2023, 07:03 AM | #6 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
See, this is crazy confusing, I got 110k on mine and already ordered the Red Line 30505 D4 Synthetic Automatic Transmission Fluid (ATF) for my M6.
Some say do some say don't. |
11-29-2023, 08:04 AM | #7 | |
Older Than Dirt
A bit off-topic since we were talking automatic transmissions here, but several people have went to the Redline in the past with mostly fine reviews for their M6. The GM fluid that came in your M6 originally is just a modified Dex III mixture (that you shouldn't put in an older automatic transmission). And you DON'T want to use Dex VI in your M6. I personally use Mobil 1 Multi-vehicle ATF in the ZL1's M6 and it's been perfectly fine. And <10 bucks/quart at Summit.
11-29-2023, 08:15 AM | #8 |
Life's just a Ride
Thanks for clarifying el ess. I'm just a N00b still learning about Car Engines lol.
