04-18-2018, 08:43 AM | #1 |
Drives: 2018 Camaro RS Join Date: Feb 2017
Throwing CEL after installing Solo HFCs
I just installed the SOLO HFCs onto my LS3 and got a CEL, reading P0137. I was told different things such as it’s front or rear O2 sensors that’s not working properly. Would replacing them most likely fix the issue?
04-18-2018, 09:23 AM | #2 |
Drives: Camaro 2ss/rs Join Date: May 2016
did you use a extender for both rear o2 sensers????if not that's what you need to do. the front ones don't use them its the rear that pics up if theres no cat or a modification change. by pulling them somewhat out of the pipe lowers the reading in them
04-18-2018, 09:28 AM | #3 |
Instagram: Sangstah
with my JBA high flows, I used these to extend the O2 sensors so you don't get a code:
http://www.bigdaddiesgarage.com/angled-cel-fix.html
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-18-2018, 10:26 AM | #4 |
I used the extenders. Just cleared the code and will see if it pops again
04-18-2018, 10:50 AM | #5 |
Started#gottalovethatblue
Have you gotten in touch with Solo yet? They may be able to offer some advice.
04-18-2018, 10:55 AM | #6 |
I emailed Solo as well. They said I could have a bad front sensor. But most people are telling me it’s the rear sensors.
04-18-2018, 11:57 AM | #7 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Down stream Extenders or tune them out .
OLD GUY FLYING FAST AND LOW
04-18-2018, 12:24 PM | #8 |
SOLO sent me an O2 extender and it cleared my CEL
04-18-2018, 08:59 PM | #9 |
I reset the fuse box and it hasn't come on yet all day. hopefully lol
04-18-2018, 09:43 PM | #10 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
get in touch with dynoSteve at RDP for one of their SCT/tune for life deals...enjoy a whole new ride...peace
04-18-2018, 10:20 PM | #11 |
SS
I got them online for 10 bucks clean install no codes great power from them solos with NBA shortys 419 hp
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
04-19-2018, 02:31 AM | #12 |
Drives: 13' 1LE Join Date: Apr 2012
Well I've always had CEL with my JBA mid pipes. Maybe the 90 degrees angles work better, but I had O2 extension and still had CEL. I just ignored em.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-19-2018, 05:52 AM | #13 |
Tri-County Camaro SWFL
My thread on the issue. If you dont want to read...... solo 02 extenders still caused a CEL. I had to pair those extenders in addition to the bigdaddies angled extenders.
http://www.camaro5.com/forums/showthread.php?t=382179 I installed these cats in 2014, and still no CEL. Even had shorties on for a little, no CEL
04-19-2018, 08:38 AM | #14 |
Well hopefully it stays off. Mine is paired with BBK shorties. Work is 20 miles one way and hasn’t turned on since Tuesday.
I was advised to replace the steel wool in the extenders but I have not yet |
