12-17-2013, 09:38 AM | #1 | |
Black Widow
Drives: 2014 Camaro 427SS Join Date: Nov 2013
800rwhp - First phase of the build complete!
2014 Camaro 2SS/1LE 6.2L 376c.i. LS3 Manual 6-Speed, 3.91 Rear Differential 100% Built/Tuned/Maintained by Lethal Racing Powertrain Mods *Whipple 2.9L Supercharger w/ 3.5" Pulley & Air-To-Water Intercooler @ 13psi Boost *Lethal Racing Custom Night Fury Camshaft *LS3 Cylinder Head Upgrade - Manley .700 Dual Valve Springs & Retainers, Comp Cams LSX Rocker Arms & Trunnion Upgrade, ARP Head Studs *Lethal Racing 5/16th 7.400 Hardened Pushrods *ARP Camshaft Bolts *Stock Crankshaft, Connector Rods, Pistons, and Bearings *Stainless Works 1 7/8" Long Tube Headers *Catalytic Converters Deleted & NPP Exhaust Deleted *Ported Throttle Body *Cold Air Inductions CAI & High Flow Cone Filter *C5R Timing Chain & GM 3-Bolt Timing Gear *Melling 10296 Oil Pump *Lethal Racing Gasket & Seal Package *ECS Alky Control Single Nozzle Methanol Injection System * Stock ZL1 Fuel Pump & Siemens 63lb/hr High Flow Fuel Injectors *MSD Fuel Pump Booster *NGK Spark Plugs *Mobil-1 Synthetic 5W30 Engine Dress Up Mods *Holley Valve Covers - painted GM Victory Red *OEM 1LE Strut Tower Brace - painted GM Victory Red *Billet Fluid Caps w/ Carbon Fiber Inlay *Billet Fuse Box Cover *Billet ECM Cover *Billet Oil Fill Cap w/ Filter Breather *Custom Lethal Racing Decals Exterior Mods *MPD1 Z-Force Ram Air Hood *5% Suntek Window Film *Custom Supercharged 1LE emblems by EmblemPros *Custom "Black Widow Edition" Decals by Trinity Graphx *Carbon Fiber Bow Tie Emblem decal overlays *Xenon Hyper Blue HID Bulbs - Low Beam Headlights *Xenon Hyper Yellow HID Bulbs - Fog Lights *Mickey Thompson ET Street Slick Radials (305/35R20-Rear) *Custom Lethal Racing Decals Interior Mods *Custom Supercharged 1LE emblem by EmblemPros *Custom "Black Widow Edition" embroidered Leather Seat Head Rests by Trinity Graphx *Hurst Short Throw Shifter *ZL1 Aluminum Brake, Clutch, Accelerator Pedals *93 Octane Pump Gas/Methanol Injection indication LED's *Lethal Racing Custom ECM Toggle Switch - On The Fly conservative/aggressive ECM Tune Change
100% Lethal Racing Built/Tuned/Maintained *Black Widow Camaro 427SS* Last edited by 1 BADD 1LE; 12-18-2013 at 09:40 AM. |
12-17-2013, 09:52 AM | #2 |
HMC(ret)
Drives: 2017 1LE(Traded In for a truck) Join Date: Oct 2013
So the question is...how much do i need to save for this? Amazing
12-17-2013, 10:00 AM | #3 |
Drives: blown Join Date: Nov 2013
that is one bad bitch. 800rwhp on stock bottom end huh? very nice.
VF Commodore
LSA Heads Cam Weld |
12-17-2013, 10:50 AM | #4 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Why did you change the ZL1/1LE shifter for the Hurst?
12-17-2013, 10:59 AM | #5 |
Black Widow
@ Bhobbs - I didn't care for the look of the suede shifter, so I changed it out!
100% Lethal Racing Built/Tuned/Maintained *Black Widow Camaro 427SS* |
12-17-2013, 10:59 AM | #6 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
Awesome. The video says it has been removed by the user.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
12-17-2013, 11:00 AM | #7 |
Black Widow
@ 20141le - Contact Lethal Racing in Lafayette, LA - they will let you know the cost, as mine is a custom build and not a package build - Lethal Racing is the best in the country, no BS!!!
12-17-2013, 02:23 PM | #8 |
Drives: 2014 Camaro 1LE Summit White Join Date: Oct 2013
Is all the running gear stock? Axle's, drive shaft, mounts, etc... If so that is great to know our car's can handle that much! Awesome build by the way!
Ordered 10-1-13 TPW- 10-28-13 Delivered 11-12-13 |
12-17-2013, 02:48 PM | #9 |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
Awesome build, subscribed! I emailed Whipple after hearing about your hood clearance issues and they are going to make available a different heat extractor that should eliminate that issue if anyone is interested.
