12-24-2009, 10:55 PM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
What do you use to clean the dash??
At the moment I have been using a Mild wet shop rag that is soft with plain ole water and then dry. Havent really thought about doing the amoral stuff yet, but wondering what others use...
By the way is that the base speaker in the forward dash or tweaters?? |
12-25-2009, 02:49 AM | #2 |
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6 Join Date: Jun 2009
California duster. Don't know about the speakers.
12-25-2009, 08:36 PM | #3 |
Leather cleaner or leather lotion. Its cleans and doesn't leave it greasy like other products.
12-25-2009, 11:27 PM | #4 |
Drives: 2017 Camaro SS Join Date: Oct 2009
Stay away from armorall on the dash. The flat finish on the dash becomes shiny and
reflects on the windshield. Also the sun causes a greasy mess on the inside of the windshield. Just continue wiping with a damp cloth to pick up the dust. |
12-26-2009, 06:24 AM | #5 |
Drives: 2010 camaro rs/ss 67 camaro Join Date: Aug 2009
I agree at best a mild soap.The armorall has petroleum products in it which causes the vinyl to eventually harden then crack
12-26-2009, 10:07 PM | #6 |
Drives: 2010 Camaro 2LT RS Join Date: Sep 2009
Service Advisor at the dealer told me ...
Don't use anything but water on dash or leather seats ... Said Armorall or other leather conditioners will do more harm than good over time. She said she has done this with her truk for 7 years and her leather looks like new.
2010 Camaro 2LT RS - Rally Yellow
Ordered from Tom Bell 1100 Prelim. Order - (09-18-09) 2000 GM Accepted - (09-22-09) Order NPJWCM. 3000 Prod Control Accepted - (10-14-09) TPW 11/02/09. 3300 Scheduled - (10-26-09) 3400 Broadcast - (10-31-09) 3800 Produced - (11-06-09) VIN 2G1FC1EV6A9165272 4200 Shipped - (11-09-09) Rail ETTX701486 5000 Deliver dealer - (11-27-09) 6000 Deliver customer - (11-27-09) |
12-26-2009, 10:10 PM | #7 |
Funny ... my son mentioned this yeasterday ... I happen to be in the store today, saw one and picked it up. Hope is is good ...
12-26-2009, 10:17 PM | #8 |
Thx TZD.
Drives: 2010 Supercharged Custom Camaro Join Date: Oct 2008
damp cloth
In many cases this isn't even keeping up with the Jones's, this is Jonesing and just plain KEEPING UP!!!
12-26-2009, 10:21 PM | #9 |
12-26-2009, 10:31 PM | #10 |
Camaro Girl ~
Damp 100% cotton cloth
12-27-2009, 12:58 AM | #11 |
Drives: 2013 SVT Raptor, sold 2010 Camaro Join Date: Jul 2009
only damp cloth
12-27-2009, 01:59 AM | #12 |
DIRECT from GM for the Camaro:
To keep the vehicle interior looking the best, it should be cleaned often. It is important to keep the upholstery from becoming heavily soiled. The vehicle's interior can experience extreme heat, which can cause stains to set quickly. Lighter color interiors may require more frequent cleaning. Care should be taken because newspapers and garments may transfer color to the vehicle's interior. Many of today's interiors are made with new low gloss materials. Permanent damage may result from using cleaners on ANY surfaces (interior trim, instrument panel, carpet, leather, vinyl and fabric) for which they are not intended. Using non-approved products can actually set the stain to the point that nothing can remove it. Important:• Do not use silicone or wax-based products or those containing organic solvents (such as naptha, alcohol, etc) to clean your vehicle's interior because they can alter the appearance by increasing the gloss in a non-uniform manner. The increase in gloss may cause annoying reflections in the windshield and even make it difficult to see through the windshield under certain conditions. • Never use a STIFF brush or a brush that has been previously used with a harsh chemical. This can cause damage to the vehicle's interior surfaces. • Use only mild, Neutral-pH cleaners. Avoid laundry detergents or dishwashing soaps with degreasers. Using too much soap will leave residue that leaves streaks and attracts dirt. Because it is critical to use only mild, neutral-pH cleaners, General Motors has approved the use of the cleaners and conditioners listed in this bulletin for the cleaning of interiors. These products are in the neutral-pH range and will maintain the best vehicle interior appearance. These products are water-based, biodegradable, and do not contain bleach, solvents or harsh chemicals. Because it is critical to use only mild, neutral-pH cleaners, General Motors has approved the use of the cleaners and conditioners listed in this bulletin for the cleaning of interiors. These products are in the neutral-pH range and will maintain the best vehicle interior appearance. These products are water-based, biodegradable, and do not contain bleach, solvents or harsh chemicals. Effective cleaning steps for hard and/or plastic surfaces: 1. Using a clean towel, apply/spray cleaner -- leather, vinyl, plastic, interior paint, directly onto the towel. 2. Wipe the surface with the towel/cleaner. 3. If necessary, use a soft bristle brush to work cleaner into the crevasses of the area being cleaned. 4. Wipe off any excess cleaner from the surface. 5. Using a clean towel, apply/spray the conditioner (leather, vinyl restorer) directly onto the towel. 6. Wipe the conditioner onto the previously cleaned area to restore the material to it's original luster. Important: Today's interiors are developed and intended to have a low-gloss appearance. It is important to use only products which provide a low-gloss finish in order to maintain the interior's integrity, customer appeal and satisfaction. Effective cleaning steps for fabric: 1. Remove any residue by lightly rubbing the surface with a clean towel. 2. Choose the appropriate stain remover based on the stain type. 3. Spray and lightly brush the area with a clean, soft bristle brush. 4. Gently blot up the stain. 5. On upholstery/carpet, the use of a fabric protector can help to reduce or eliminate future staining. Leather Conditioner/Restorer A Leather Conditioner/Restorer is also available. The restorer is safe for all vinyl and leather. It is a water-based product and contains essential emollients to restore suppleness, conditions and adds luster without adding gloss. The restorer will also provide protection against restaining. Dye Transfer: Dye transfer will happen any time a natural fiber like cotton, silk, wool, or suede comes into contact with leather. The lighter the leather color, the more quickly the dye transfer will appear. Leather should be cleaned on a regular basis so that the dirt and grime do not adversely affect the top coat of the leather. After cleaning the leather, it is important to treat the surface with the restorer. Products are available from your local GM dealer. |
12-27-2009, 01:08 PM | #13 |
Drives: '10 Corvette GS/'13 Mustang Join Date: May 2009
Leather cleaner
07-19-2010, 05:47 PM | #14 |
Drives: #3124!!! Join Date: Apr 2008
Anyone have a preferred neutral p-H cleaner?
Similar Threads | ||||
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Anyone else having trouble keeping the interior clean?? | Betsi1214 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 24 | 12-05-2009 11:18 PM |
Factory dash ABL? | bkwagonss | 5th Gen Camaro SS LS LT General Discussions | 3 | 09-17-2009 10:41 AM |
'69 Door & Dash Emblems Mod | tjd24 | Cosmetics and Lighting Modification Discussions | 15 | 08-24-2009 09:46 PM |
Mr Clean Auto Dry & waterblade? | Matt'sSS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 08-17-2009 12:19 PM |
