07-06-2017, 11:26 PM | #1 |
Car drives without key fob
Just like the title says,
So yesterday a buddy came over to check out the 1LE. I fired up the car and pulled it out of the garage. I ran in the house to grab my wallet but before I went in I set the key fob down on my work bench as not to freak out the car. I ran out hopped in the car and went for a short drive to show my friend how well the car handles, drives and some of the creature comforts. All this was done with the key fob sitting on my workbench back home. We pulled back into the driveway and I thought the key fob had fallen out of my pocket in between or under the seat. After several minutes of going nuts I realized that I had set the fob on the workbench and sure enough there it was. Now i'm left to scratch my head, i didn't realize this was possible and figured the vehicle would shut off if the key fob wasn't within a specified distance.
I pick things up then put them back down.
07-06-2017, 11:36 PM | #2 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
Mine will drive without it as long as you start it with the FOB in the car. It will warn you on the DIC as I recall but will not shut down.
It will not restart without it though. I think this is a saftey feature. I had an issue with mine where the battery was not seated right and it would only intermittently work. It would have been a much larger issue if the car randomly cut off on me in traffic. Whiskey |
07-06-2017, 11:42 PM | #3 |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
There are obvious safety issues if the car were to suddenly shut off after moving out of range of the key fob. All it takes is for one car to shut itself off on some train tracks, or in a tunnel, or on a blind corner somewhere to cause an accident. Because of this I am sure it is working as intended.
07-06-2017, 11:54 PM | #4 | |
07-07-2017, 12:32 AM | #5 | |
Drives: 2016 Camaro RS Join Date: Jul 2016
Its pretty sensitive too, even if the fob is just outside the door and the car is on, the DIC will start dinging with the "Remote Not Detected" notification. |
07-07-2017, 07:07 AM | #6 | |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
07-07-2017, 11:06 AM | #7 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The dash will tell you the key is no longer in the car, and when you shut the door the horn will honk twice as an additional reminder. Not sure what else the car should do, two warnings should be enough.
2017 "M1SS1LE" in Hyper Blue w/PDR
07-07-2017, 01:44 PM | #8 |
Yeah, I had no such warnings which I have noticed the short honks when I get out to lock my garage. This time there were no warning honks or display on the dash.
07-07-2017, 04:49 PM | #9 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Every car with a wireless key I've used will keep the car running once started but don't turn it off or you'll find out you left your key somewhere
