Old 04-12-2019, 02:13 PM   #1
@ReaperZL1
Drives: 2013 camaro zl1 aka the Reaper
braided stainless steel brake lines
has anyone done the conversion to braided stainless lines on their zl1, I would love to get 1st hand thoughts and opinions on doing the conversion, how easy it is to do and responsiveness. also what about brake fluid, which one is everyone running for road coursing?
@ReaperZL1 is offline   Reply With Quote
Old 04-12-2019, 03:51 PM   #2
carparts
carparts's Avatar
Drives: 2014 Z28 Black 2010 WF1 Stohr
i did Spiegler steel braided lines on my Z28 much firmer pedal
wilwood 600 brake fluid
carparts is offline   Reply With Quote
Old 04-12-2019, 04:20 PM   #3
@ReaperZL1
install
did you do the install yourself?
is that one better than Castrol SRF fluid?
Old 04-12-2019, 04:31 PM   #4
@ReaperZL1
also how long have you had them on, and have you had any issues yet?
Old 04-12-2019, 07:25 PM   #5
carparts
carparts's Avatar
Yes I did the install my self I took a couple hours. I'm not a fan of the SRF brake fluid Motul or willwood is much better brake fluid. I have only had my Z28 for a little while. But I've had many road race cars and motorcycles over the years. It's a dramatic different feeling brake pedal
Old 04-12-2019, 08:25 PM   #6
@ReaperZL1
brake lines
I appreciate all the info man
Old 04-13-2019, 11:39 AM   #7
Tomsusername
Tomsusername's Avatar
Drives: Velvet Blue Metallic 2015 1SS 1LE
As do I.
@ReaperZL1, thanks for the bump on this subject!
Also, will 2nd that Motul makes great fluid. I've ran DOT 5.1 and RBF600 in the past.
I can't vouch for SRF. All I know is that it's REALLY expensive, and I've heard a handful of guys claim that it supposedly "will not" boil. I feel like Wilwood or Motul is probably better bang for the buck. carparts also probably has more experience with this than I do.
Tomsusername is offline   Reply With Quote
Old 04-13-2019, 04:46 PM   #8
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
I went from factory fluid, to Castrol SRF, and then to Motul. I like the Motul as the Castrol works well but is not cost effective. The steel lines helped brake pedal feel.
ZL1-V is offline   Reply With Quote
Old 04-14-2019, 10:13 AM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I dont have a ZL1, but did the same upgrade. Made the pedal firmer, along with more confident. Easy and cheap upgrade.
More to come.
Black_SS10 is offline   Reply With Quote
Old 04-14-2019, 04:18 PM   #10
@ReaperZL1
brake lines
thank you everyone for all the info. yeah the SRF is not really cost effective. I'm going to go motul this go around and test it out. I have new pads and slotted/drilled rotors coming in from R1 Concepts as well.
is this the correct sight, just want to double check before I order.
https://www.essexparts.com/spiegler-...t-camaro-sszl1
Old 04-14-2019, 04:56 PM   #11
carparts
carparts's Avatar
Yes those are the best quality ones I've found
Old 04-14-2019, 06:04 PM   #12
@ReaperZL1
brake lines
very well ,then ill probably be ordering those in the next week or so.
I'm brain farting right now but what about the rear. I forget lol
Old 04-14-2019, 10:32 PM   #13
DrkPhx
DrkPhx's Avatar
I installed the Goodridge SS lines and Castrol DOT 4 synthetic fluid at the same time. Definitely has a firmer pedal, but it could be from the brake bleeding.
Old 04-17-2019, 04:27 PM   #14
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
If the rotors are getting hot enough that you're needing Motul fluid, they will crack at the cross drilled holes fairly quickly.
h018871 is offline   Reply With Quote
