Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Interior Parts & Accessories
Old 08-07-2015, 01:26 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
AeroForce Interceptor: The Do-Everything Gauge, ships FREE @ PFYC-PartsForYourCar
Get our "do everything" gauges shipped free at PFYC - PartsForYourCar!
I have one of these in my personal daily driven family/performance car along with two analog add-on sensors for boost and air/fuel ratio and absolutely love it. Once you begin monitoring your car's normal operating data and numbers, you'll have a hard time driving without it.
If you haven't seen our AeroForce Interceptor OBD2 plug-n-play scan gauges, you are missing out. These insanely cool gauges can show 2 parameters at once and have a huge host of other cool features. Here is only some of what they can do - to find out more, click the image below.
Use promo code THISTHINGROCKS for a limited time to get free shipping in the continental USA on these and any related add-on sensors. Also check the store for mounting options for your car.
Quick Feature List:
  • Plug and play installation using your car's OBD2 port
  • Multiple face and LCD color options to match any interior
  • Multiple logo options and bezel colors
  • Display 2 parameters at once but can be configured to cycle through 8 at a time
  • Built-in programmable shift and warning lights - set what you want to monitor to turn a light on at a pre-determined value
  • Read and clear diagnostic trouble codes (DTCs) from the gauge itself
  • Two analog inputs for anything you want to add
  • Bi-directional controls allow you to have manual control over various features
  • Measures 0-60 times and 1/8 and 1/4 mile times and speeds
  • "Record Mode" allows you to record data for later playback
  • Sample parameters you can monitor (not all available on all vehicles): RPM, MPH, intake air temp, coolant temp, trans temp, voltage, fuel temp, exhaust gas temp, fuel trims, O2 voltages, advance, spark, throttle position, load, HP, torque, lateral G force, yaw, steering angle, etc
  • Extend functionality by adding on our sensor kits sold separately (these also ship free with the same promo code)
AeroForce OBD2 Interceptor Scan Gauges at PFYC.com - PartsForYourCar
To see a full listing of our brand new 2010-2015 Chevrolet Camaro items, please click here.
To see a full line-up of our current sales and specials for your 2010-2015 Chevy Camaro, please click here.
PFYC is offline   Reply With Quote
Old 08-28-2017, 01:15 PM   #2
PFYC
PFYC's Avatar
Drives: Yes
Old 12-13-2018, 08:16 AM   #3
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!
Old 07-28-2022, 01:14 PM   #4
PFYC
PFYC's Avatar
Drives: Yes
http://www.pfyc.com/GN2118.html
FEATURES
"Record mode" available - records displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored
Displays two parameters at a time, but can be programmed to cycle through up to 8 parameters during a determined period of time
Built-in high intensity LEDs can be used as shift lights or warning lights to indicate when a selected parameter exceeds a threshold you have configured. Due to the gauges' extremely fast update rate, this light is very accurate and easy to set
Swap the foreground and backround colors of the display using the menu buttons. (Ex. a gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image))
Adjustable scan rate
DTCs (Diagnostic Trouble Codes) can be accessed and cleared via the menu menu options
Two configurable analog inputs with available linear conversion and recording capability (these inputs are handy for pressure signals such as those from MAP and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc.)
Bi-directional controls allowing for manual control of the low and high speed fans, CASE relearn and ECU reset on GM vehicles. On most Chrysler vehicles, the transmission controller can be reset and Electronic Stability Program can also be completely disabled.
Optional relay output module allows you to control an external 12 volt relay based on values of OBD2 or analog data
Measures 0-60 times as well as 1/8 and 1/4 mile time and speeds
Literally plug-and-play installation
Old 08-23-2022, 02:57 PM   #5
PFYC
PFYC's Avatar
Drives: Yes
Thank You for Shopping at https://www.pfyc.com/GN2118.html
