Old 03-29-2018, 12:16 AM   #1
infernostripes!
Drives: 2010 1ssrs
Driver's side passenger carpet is wet
Does anyone have any experience dealing with a water leak?
I have a 2010 camaro and the driver's side passenger carpet is wet after driving in the rain. The weird thing is that the edges/borders of the carpet are not wet. Only the bottom part where the feet rest is wet!
Thanks for the help!
infernostripes! is offline   Reply With Quote
Old 03-29-2018, 06:55 AM   #2
Rob Russell
Rob Russell's Avatar
Drives: 2014 Camaro SS L99
How many miles? Do you have a sunroof? Have you ever had your windshield replaced?
Rob Russell is offline   Reply With Quote
Old 04-10-2018, 06:52 AM   #3
cbear34
Drives: 2012 2SS
I have a 2012 that had/has a leak similar to what you're describing. It's only happened once since I've owned the car but it was right after a heavy rain. The only spot that was wet was the driver side passenger in the floor just as you described. I'm going to do a water test this week so I'll post again if I find anything.
Just curious, does your car have a sun roof? Mine does so one of the first things I thought of was possibly a clogged drain.
cbear34 is offline   Reply With Quote
Old 04-10-2018, 06:40 PM   #4
InfernoB
Drives: Camaro 2SS RS L99 Blk with IOM pkg.
what is a drivers side passenger carpet? are you saying the drivers side rear... or just the drivers side; kinda hard to be on the driver and passenger side at the same time?
either way, its the seal behind the door panel. happened to me too...
on the drivers side rear floor board... for the passenger LoL
InfernoB is offline   Reply With Quote
Old 04-12-2018, 03:52 PM   #5
SneakySS
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow
You’re running your ac with your windows down. Ac condensation is dripping out da vent maybe
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam.
Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s
Build and mods done by R&D Motorsports in Baton Rouge
Tune/Dyno done by ,,Engine Power Systems in Baton Rouge
SneakySS is offline   Reply With Quote
Old 04-14-2018, 07:43 PM   #6
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Can you please post a pic of this seal location?
I had this happen to me once also, the rear right side foot well. Only once and it was only the bottom that was wet.
Thanks
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
