06-23-2020, 10:42 PM | #1 |
Drives: 2014 Camaro LT2 Join Date: Mar 2020
Bent control arm?
I bumped a curb this morning with my right front tire while rounding a
turn at about 10-15 mph. It tweaked something but also caused my stabilitrak warning to come on as well as disable traction control. I pulled the wheel and looked at everything but didn't see anything obvious that was bent. I figured the tie rod would be pretty noticeable if that bent. It appears perfectly straight. The only other thing I saw that looked like it could possibly bend based on the way the wheel hit is the lower forward control arm. It's hard to tell if it's bent because it has an intentional curve to it. Anyone know what would be the most likely things to consider? I'd prefer not to buy a bunch of parts to see what fixes it. Also, I'm not sure why the stabilitrak was affected by it. Any insight is appreciated. Thanks. |
06-23-2020, 10:52 PM | #2 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i bent mine also
06-23-2020, 11:26 PM | #3 | |
06-23-2020, 11:27 PM | #4 |
06-23-2020, 11:42 PM | #5 |
06-24-2020, 06:36 AM | #6 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I think it was from when I ran a deer over on the highway a year a half ago and got 3 wheels off the ground. I didn't get any codes or anything I just needed 2 new front wheel bearings and a new fascia. Get your Stabilitrac codes read at AutoZone.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
06-24-2020, 07:37 PM | #7 | |
06-24-2020, 10:52 PM | #8 |
waiting at the tree
Transport truck hit Bambi in the right lane and it spun off the front of the truck into the left lane as I was passing the truck.
It happened at about 1am when I was driving home from the Bills vs Patriots Monday Night Football game.
06-28-2020, 02:16 PM | #9 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
06-29-2020, 11:29 AM | #10 | |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
06-30-2020, 09:44 PM | #11 |
I replaced the lower forward control arm and inner and outer tie rod. It had no effect on the issue. I adjusted the tie rod so the the wheel was relatively aligned with the other so it is a little more driveable to get it to an alignment shop this weekend. Adjusting the tie rod got rid of the "service stabilitrak" warning. I'm eager to find out what got so jacked up from a minimal impact.
Thanks for all the input so far. I'll follow up. |
