Old 07-20-2011, 10:24 AM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
elite oil catch can
Hello, I just checked my elite catch can, and was amazed on how much oil was in there... it was more then a quarter filled with only a few thousand miles on it.. just to think of all that oil going into the intake.. I do have one question, I poured the oil back into the engine... after thinking about it was that the right thing to do.. if its not should I get a oil change.. oh another thing, I remember seeing a thread on how the catch can fell off the post and caused alot of damage with the pulleys and things, mine was loose also, so I made it tight again and will keep an eye on it for a while.. if you have one make sure you check it once in a while..
MARINE1991 is offline   Reply With Quote
Old 07-20-2011, 11:17 AM   #2
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Pouring the oil back in the engine shouldn't be a problem assuming the catch can is free of manufacturing debri. You might try some Locktite on the threads of the mounting hardware on the catch can.
I recently removed the throttle body on my engine and found oil on the floor of the intake manifold...so I'm in the market for a catch can.
Cam 427 is offline   Reply With Quote
Old 07-20-2011, 11:19 AM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I would not pour it back in. I would think the oil vapors it catches is broken down oil but what do I know.,
Pollock is offline   Reply With Quote
Old 07-20-2011, 12:51 PM   #4
MARINE1991
MARINE1991's Avatar
I will do that if it loosen back up..
Old 07-20-2011, 01:20 PM   #5
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Don't pour it back in. More than just oil is in there. Other stuff you can't see is mixed in. Just empty it when you change your oil and you should be good.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 07-20-2011, 01:54 PM   #6
SC2150
NEVER put what comes out of your can back in to the crankcase!!! alnog with the oil the can caught, it also contains the harmfull combustion by-products. Just a few I'll list:
Unburnt fuel (dilutes the piol and reduces the lubricating properties)
water (the amount of water vapor removed for the crankcase is amazing)
carbon particles (very abrasive, and not what you want in your oil)
Sufuric acid (a result of mixing of the other compunds and very corrosive to the internal parts)
and a ton more.
The oil caught should be disposed of as your drain oil is.
Old 07-20-2011, 02:05 PM   #7
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
You said your catch can was loose, you might want to check this out.
http://www.camaro5.com/forums/showthread.php?t=155468
Bo Tie 1 is offline   Reply With Quote
Old 07-20-2011, 02:31 PM   #8
MARINE1991
MARINE1991's Avatar
Yea I seen that thread that is why I went to check out mine and it was loose... Ok thanks I will not do that ever again...
Old 07-20-2011, 02:41 PM   #9
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
With all the extra stuff listed in SC2150's post, I would suggest you do an oil change immediately to get that stuff out of your engine.
stso634 is offline   Reply With Quote
Old 07-20-2011, 02:55 PM   #10
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
and a ton more.
While I agree that I would not pour the oil back into the engine...it's important to note that all the things that you mention were about to go back into the combustion chamber had the catch can not been in place. So it's not like you're dumping a sand and gravel back into your oil.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 07-20-2011, 02:56 PM   #11
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
You should send a pm to EE on this site. They will send you a new mounting bracket or bolt. The problem with the original mounting method is not that the bracket will come loose, but rather that the stock bolt will eventually snap from fatigue. You need to get one of the new brackets or bolts. Read that thread others have pointed you to. I got my new bracket this week.
Old 07-20-2011, 03:15 PM   #12
MARINE1991
MARINE1991's Avatar
I might due just that...
That is what I thought when I did it, but not sure..
I really like the way its mounted now, so I just dont know..
Old 07-20-2011, 03:18 PM   #13
Darth_Emma
Darth_Emma's Avatar
The will send you a stronger bolt so that you can mount it in the same way it is now, but he new bolt won't break.
This problem has occurred on several cars. You don't want to leave it as is with the stock bolt.
Here is the post: http://www.camaro5.com/forums/showpo...&postcount=100
You want the new bolt (option A) if you want to keep it mounted in the same location it is in now.
Old 07-20-2011, 03:19 PM   #14
MARINE1991
MARINE1991's Avatar
Ok thanks I just sent them a PM with my address..
GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 SQUALO Canada 56 04-21-2011 03:19 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 04:50 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
