Old 05-10-2012, 06:15 PM   #1
Nessal
Drives: Exige, Miata, Ghia
What lug nuts are you guys using on your Forgestars?
As the title says.
Nessal is offline   Reply With Quote
Old 05-10-2012, 06:31 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I use the cheapy $30 Ebay ones. The black paints chips off very easily so I don't use air tools on them.
http://www.ebay.com/itm/260913526826...84.m1439.l2649
SUX2BU is offline   Reply With Quote
Old 05-10-2012, 08:47 PM   #3
Nessal
I heard no gorilla locks fit the forgestars.
Old 05-10-2012, 09:08 PM   #4
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
False. I use gorilla on both my 20 and 18 inch forgestar F14's
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-10-2012, 09:14 PM   #5
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
How about aluminum and drop .5lb per wheel > http://www.uniauto-wepro.com/index.p...d=13&Itemid=23
JimE is offline   Reply With Quote
Old 05-10-2012, 09:46 PM   #6
Nessal
Which ones are you using?
Old 05-10-2012, 10:19 PM   #7
lexlueger
lexlueger's Avatar
Gorilla lugs/locks
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-10-2012, 10:25 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Gorilla lugs/locks
Nice floor. LOL
What part number are the locks? The ones I had didn't fit my 18" Forgestar F14s.
Old 05-10-2012, 10:32 PM   #9
lexlueger
lexlueger's Avatar
Thanks, it's imported from Italy. Don't have the part # On my 18 inch powdercoated f14's I had to mill a couple thousandths off the key. The lugs fit just fine...the thickness of the key is the potential issue. There is a difference between powdercoated wheel lug holes and painted ones. They also vary through size. I have 20 in and 18 inch f14's.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-11-2012, 05:03 AM   #10
ICEMAN 316
ICEMAN 316's Avatar
Drives: FAST
Gorilla locks fits Forgestar rims. I have the 22" F14's and I had to use the Gorilla lock Tuner Lug nuts 1.4mm x 1.50 for the front rims cause the lug nuts the vender gave me only worked on my rear rims.
ICEMAN 316 is offline   Reply With Quote
Old 05-11-2012, 07:58 AM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Part number?
Old 05-11-2012, 09:19 AM   #12
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
"milling the key" is not really a solution I could offer customers, haha.
Most lugs fit in the Forgestar holes, it is always the key or socket that cause the fitment issue. I recommend splined "tuner style" lug nuts. Very small diameter key, and no hassles.
Fquick.com/NineBall
Old 05-11-2012, 09:31 AM   #13
lexlueger
lexlueger's Avatar
Sometimes Vendors leave you high and dry which sometimes breeds innovation...yes that was a shot. Good day to you...
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-11-2012, 05:46 PM   #14
ICEMAN 316
ICEMAN 316's Avatar
Drives: FAST
Originally Posted by SUX2BU View Post
Part number?
I don't have a part number cause I went to a local wheel shop and asked them and he went to the back and got 10 of them for me. It's the Gorilla Tuner Spline lug nuts. It's 14mm x 1.50. This will only work on my front rims. The rear ones I just used the one they gave me which are the regular acorn Lug nuts. You wouldn't want to use the Gorilla Tuner Spline lug nuts on the rears because they would stick out to much.
Here's what the Gorilla Tuner Spline lug nuts I got looks like.
http://www.amazon.com/Gorilla-26145B.../dp/B004U3TEF0
****Again it looks just like the one in the link but I'm not sure if those are the ones****
