Old 09-12-2012, 05:08 PM   #1
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
Exclamation Emerrgency! Help
I accidently had my transmission fliud drained while changing oil! how can ZI get it back in???? Please help!!!!!
007s 'Vert is offline   Reply With Quote
Old 09-12-2012, 05:11 PM   #2
BNB
Rollin' The Lunchbox
Drives: 2012 Camaro Ashen Grey
Get a funnel and pour it back in the fill line...make sure it doesn't have metal flakes in it!!!! Best bet is use this experience wisely and get new fluid...
Sent from the front seat of the Amberlamps!
BNB is offline   Reply With Quote
Old 09-12-2012, 05:12 PM   #3
M Miller69
M Miller69's Avatar
Drives: 2010 Camaro 2SS
You better leave the fluid changes to the profesionals if you cant tell a oil pan from your Trans. . CALL a GM dealer.
RED
10' 2SS
MPD1 Hood
MPD1 spoiler
SS front splitter
SW lt Headers
VMaxx porteds TB
JRE 93 octane tune
M Miller69 is offline   Reply With Quote
Old 09-12-2012, 05:14 PM   #4
caliguy
Don't ask to pop my hood!
caliguy's Avatar
Drives: it's loud.......
Who is doing it walmart? and how do you accidently drain tranny fluid? once you see red put drain plug back in fast, thats if your doing it yourself?
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS |
2010.
caliguy is offline   Reply With Quote
Old 09-12-2012, 05:16 PM   #5
007s 'Vert
007s 'Vert's Avatar
I cannot locate the fill tube, these cars dont have a dipstick
Old 09-12-2012, 05:17 PM   #6
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
1. Don't drive it. Don't even start it.
2. I don't know if the A6 has a dipstick, but you need to find out how much fluid you drained. Each transmission has a fill procedure...some of the ones I worked on could be filled right through the dipstick. If that's the case, buy some proper fluid (there are different kinds...watch out...) and fill 'er up.
3. If all else fails, just have the car towed to the dealer or to the nearest shop that can fill a transmission.
DON'T start the car, and DON'T drive the car unless the fluid is within the normal, specified level.
1BADLS3 is offline   Reply With Quote
Old 09-12-2012, 05:18 PM   #7
007s 'Vert
007s 'Vert's Avatar
Se all make mistakes, I did a big one tonight
Old 09-12-2012, 05:18 PM   #8
1BADLS3
1BADLS3's Avatar
Well shit.
That means the fluid probably has to be pumped in from underneath. If you're not keen on how to do this...I'd just have the car towed to a shop.
Old 09-12-2012, 05:20 PM   #9
007s 'Vert
007s 'Vert's Avatar
I already started the car after I put the oil in and didnt realize it untill I noticed the oil level was way high. it seams nothing bad happened to the engine it didn't run verry long
Old 09-12-2012, 05:24 PM   #10
007s 'Vert
007s 'Vert's Avatar
The engine ran fine, I dropped all the oil and refilled it with the proper amount and ran the engine again and it ran fine, I think I only dropped about three to four quarts out of the tranny
Old 09-12-2012, 05:25 PM   #11
caliguy
caliguy's Avatar
HUH? you changed the oil but its reading high after a change? are you sure you got all the old oil out? and put in 6qts, also reset your DIC oil% to 100%
2010.
Old 09-12-2012, 05:25 PM   #12
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
I agree, I think you should just have it towed. There is a way, at least for the 6L80, to refill it by snaking a tube from the engine bay down to the fill plug. This process is easier said than done.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 09-12-2012, 05:26 PM   #13
clg_98ta
clg_98ta's Avatar
You didn't really read the thread, did you...
OP: You are not the first person to do this...
Old 09-12-2012, 05:28 PM   #14
KidKilowatt
KidKilowatt's Avatar
Drives: 2011 Camaro 2LT RS
Did you?
2011 LLT RS Black on Black Loaded. [x]Showstopper 45th Anniversary inspired Camaro RS Stripes, [x] MPD1 Spoiler, [x] GM Heritage Grille. [x] Removed RS and Bowtie Emblems. [x] 30% Tinted Headlight Armour DRL's. [X ] Ruff Racing R954 Wheels [X] Solo Cat Back Mach X-LLT Exhaust [X ] Vmax Ported throttle body [x] Halo SC Reverse Hood Kit [x] Showstopper Painted, Modded Engine Cover [x] Cold Air Inductions CAI [x] Tinted Tails and Black Bezels [x] Megan Racing Street Series Coilovers [x] Belltech F&R Sways
Check out my build thread!
http://camaro5.com/forums/showthread.php?t=212178
KidKilowatt is offline   Reply With Quote
