06-17-2014, 01:19 PM | #1 |
Drives: Camaro ZL 550 SLP Join Date: Jul 2012
Best Engine oil
Hi guys. Chevrolet in Dubai have recommended that I use 10w-60 for my car with its current mods. Considering how hot it gets in dubai, is it the best choice of oil?
Sent from my iPad using Tapatalk
Cold-Air Inductions® System | ARH 1 7/8" Headers w/o Cats | SLP PowerFlo-X Crossover Pipe | SLP Powerflo Axle Back Exhaust | TVS2300 Magnacharger w/ 3.0" pulley | NEP 223/235 Custom Cam | Lunati Gold Dual Valve Springs | Manley 7.400" Pushrods | Injector Dynamics ID850 Injectors | Nick Williams 102MM FBW Throttlebody | Eibach springs w/ 1" drop | SLP Adjustable sway bars | Forgestar F14 20" | Nitto NT555R tires | Baer Drilled & Slotted Rotors | Hawk HPS Break Pads | Lingenfelter 3.91 Gear Kit
06-17-2014, 07:01 PM | #2 |
Drives: bicycle Join Date: Jun 2014
Use whatever it is specified for your engine. I know in Europe and it seem that your part of the world has also adopted the 10W60 mentality. Normally is used for racing applications where alcohol is used for fuel.
06-17-2014, 07:08 PM | #3 |
Banned
Drives: Camaro Join Date: Mar 2013
15w/50 Mobil 1
06-19-2014, 11:38 AM | #4 |
Drives: Camaro Join Date: Aug 2013
Redline 5W30
06-20-2014, 04:05 AM | #5 |
5w30 is what your cars oil system was designed for. going heavier will just cause problems a 30w is what you need.
06-25-2014, 04:26 PM | #6 | |
The rule of thumb is never go down in viscosity but you can go up. So don't use a 5w20 or 0w20. .. but it's ok to use a 10w30 or 10w40 |
06-25-2014, 04:33 PM | #7 |
I think the important point here is that the OP is in Dubai. Due to the extreme heat, the original oil "might" not be the best option. While I usually adhere to the OEM recommendations, I can imagine that it was not designed with temperatures around 120 Fahrenheit in mind.
P.S. that's not including the radiant heat from sitting in the sun or on a smoldering road. |
06-26-2014, 01:41 PM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
What does your manual say if you purchased the car in Dubai? Just curious. Its interesting that Chevy would recommend such a heavy oil for an LS engine. Was this a mechanic's opinion or official recommendation?
The oil moves down via gravity to the main bearings from the cam area. Thicker oil may not flow quickly enough. Also the oil pump bypasses at a pretty low psi, meaning that high pressure from high viscosity causes the oil to just get dumped back in the pan. Look for an A3/C3/C4 oil to start, which are available in most 40 grades, and some 30 grades. I would go with a synthetic 5w-40. See this thread he has a similar build: http://www.camaro5.com/forums/showthread.php?t=344840. He started with 15w-50 and had better results with 5w-40.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
07-14-2014, 02:59 PM | #9 |
Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
Not entirely true. I went from 5w-30 to a 5w-20 and my UOA's didn't change. Depends on what your driving style and conditions. This was on my 2002 Silverado with the 5.3. This is in the humid hot part of eastern North Carolina where we see 100° F temps some in the summer. Thicker isn't always better especially to pull heat away from the block. To find the best protection for you specific ride and driving style/conditions, you can't beat trending a few UOA's to set you on the path to a happy healthy engine. What works for one might not work for you to many variables.
07-19-2014, 10:41 AM | #10 |
Bought Mobil1 5w30 5qt at wallywood for less than $23 today.
Magnetic drain plug for both V8 and V6 engines: M12-1.75x15mm Needa Parts p/n 653096 Dorman Auto Grade p/n 65212 Dorman p/n 65372 You're welcome. |
07-19-2014, 03:42 PM | #11 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
I went to 3 different Walmart stores and they were all sold out. I never thought it would be that difficult to find oil, but it is a hell of a deal. I finally found some at autozone for $15 more for the 5qt jug.
07-19-2014, 04:21 PM | #12 |
This should somewhat settle the OPs question, and debunk the theory of using a thicker oil that is 2-3 viscosity ranges above the recommended viscosity by the OEM. In this case an LS3, L99 is supported by 5W30, but keep in mind not all 5W30 Oils are fully synthetics and maybe blends or not even synthetics at all which these oil do not have as high of a Flash Point as the Full Synthetic.
For example the AMSOIL Signature Series 5W30 has a Flash point tested by the ASTM D-92 at 438 degrees F. And an incredible High Temperature/High Shear Viscosity at 150 degrees C of 3.2... this is a real good test that shows that when high end Oil products are used the results are very well established. |
07-20-2014, 12:24 AM | #13 |
Redline is a API Group V Esters oil and does not shear. Great oil product with a flash point of 450 degrees F.
07-20-2014, 02:13 AM | #14 |
Drives: 2010 2SS/RS Join Date: Jan 2013
Been hearing Rotella works good?
