07-19-2014, 10:23 PM | #1 |
Amsoil Z-Rod for cammed LS3 w/cats
Im running American Racing headers with the cats they now supply. How long should they last with Z-Rod?
07-20-2014, 07:47 AM | #2 |
Drives: bicycle Join Date: Jun 2014
You will be fine. They will most likely outlast the engine.
The theory of zddp harming the cats is a statement that has to be made mandated by the epa, many folks say they have never experienced issue |
08-11-2014, 04:14 AM | #3 |
Drives: 13' Black SS Join Date: Mar 2013
yep, actually the zinc is harmless it the phosphorus in the zddp chain that affects the cats
08-17-2014, 11:16 PM | #4 | |
Drives: ‘13 1LE Join Date: Jul 2013
For a cammed LS3, would the Signature Series suffice, or must one switch to the Z-Rod? |
08-18-2014, 07:13 PM | #5 |
08-20-2014, 12:27 PM | #6 |
Thank you sir!
08-21-2014, 12:11 AM | #7 |
interesting. running LS30 and I was thinking of gutting my HFC because of this reasoning
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
08-21-2014, 01:36 AM | #8 |
Drives: 2011 Camaro SS/RS Join Date: Dec 2010
hey there andy, im soon going to be forged, cammed and twin turbo and was wondering which of the amsoil products you would suggest
2011 SS/RS @ home 12/28/2010
08-21-2014, 06:19 PM | #9 |
1. For pure racing and better protection, specially for large cams.
http://www.amsoil.com/shop/by-produc...code=RD50QT-EA 2. For racing and street driving. http://www.amsoil.com/shop/by-product/motor-oil/gasoline/z-rod-20w-50-synthetic-motor-oil/?code=ZRFQT-EA 2. Another good option is the Euro 5W40, there are a few 1800 HP GTRs using it. http://www.amsoil.com/shop/by-produc...?code=AFLQT-EA |
08-21-2014, 10:02 PM | #10 |
Andy, for Racing and street driving, am I reading correct, that you recommend 20W/50??
Isn't that a tad too heavy? |
08-21-2014, 10:27 PM | #11 |
you should NOT run 20w50 in a LS motor. z rod 10w30 is fine.
08-22-2014, 11:57 AM | #12 | |
Remember the key point here is that once your engine is built your engine builder will spec an oil viscosity,, he should not mandate which brand of oil but which viscosity. But if your block is stock then Sig Series 5W30 or Zrod 10W30 even better |
08-22-2014, 11:59 AM | #13 |
^^^Thanks man
