09-07-2014, 12:51 PM | #1 |
618 RWHP
Drag Racing and PTM modes ?
What is the best PTM for drag racing with a dry track for the best time ?
09-07-2014, 01:18 PM | #2 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
5 is programed for a prepped surface..
09-07-2014, 01:37 PM | #3 |
Drives: none Join Date: Aug 2011
None.
09-07-2014, 01:56 PM | #4 |
Drives: 2013 ZL1 Join Date: Oct 2013
I find no difference time wise really between 5 and off.. I have broke into the 11's bone stock in 5. Use what ever works best for you by trying it out. Don't go by what us Internet experts tell you.. lol
2013 Silver ZL1
09-07-2014, 03:56 PM | #5 |
Drives: 2013 Camaro ZL1 Victory Red A6 Join Date: Jan 2011
None. put it in M "sport mode'' and let the car do the rest. On street tires keep all the nannies on and if your on DRs or Slicks take it all off.
09-07-2014, 03:58 PM | #6 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
I turn mine completely off.
09-07-2014, 04:58 PM | #7 |
618 RWHP
09-07-2014, 05:05 PM | #8 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
When I was over 750 whp on street tires PTM 3 was how I got my fastest times. I could smoke the stock tires at will in the first 3 gears. Once I got a set of drag radials, hold the button for 7 seconds and turn it to the "all off" mode. It doesn't need traction control if the tires stick. If you are totally stock on stock tires you might be a little faster in PTM 4 but I would burn out "all off" and then push up the PTM while you are staging the car.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
09-07-2014, 06:04 PM | #9 |
Drives: '21 ZLE A10 Join Date: May 2012
none is best
09-07-2014, 06:32 PM | #10 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
PTM 5 runs about .3 slower than just turning traction control off. In my experience with 2 near stock ZL1s
