Gen5DIY
Old 11-11-2017, 08:56 PM   #1
JOURDAN
Drives: 2010 Camaro SS 2SS
Cooling System Pressure > 24H after last run
I am really hoping the community can help me do a few experiments.
I had been fighting coolant leaks and engine not holding pressure, air in system.
After correcting all leaks and bleeding the system holds pressure very well now.
However here is the problem, Like the title says... 24 hours later she is still under pressure.
The cooling system WILL NOT pull coolant BACK INTO reservoir because ZERO Vacuum every happens.
The cooling system will purge out about 1" of coolant and then NO MORE coolant will be transferred to reservoir. The coolant stays even with top of coolant fins inside.
So... in some way the system is stable, but under pressure and not functioning correctly.
No other symptoms exist with exception I still smell a tiny tiny bit of coolant after working her.
My first thought is I have a BAD HEAD or GASKET and combustion gasses are getting INTO my cooling system.
I'm puzzled... Need help ....so I don't take this thing apart for nothing.
Would anyone who can see if their Camaro 6.2 is still under pressure after cold 24 hours or even less, just all the way cold again??
If you listen to your reservoir bottle when releasing radiator cap you would hear it blowing bubbles in your bottle.
Thanks in advance!!
JOURDAN is offline   Reply With Quote
Old 11-12-2017, 01:21 AM   #2
JOURDAN
I just preformed a bottle test, put the reservoir tube into a bottle of water and with engine up to temperature I observed zero air bubbles in bottle, even revving engine.
If it were combustion gases I would think bubble would appear as the cap let off pressure
Old 11-12-2017, 08:32 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
With the age of your Camaro now you should have changed out all the antifreeze with a flush to avoid acidity which it builds over time that can pit badly aluminum and the radiator cap which does weaken. And no there is no pressure after a while it dissipates....I would suggest changing out the radiator cap. The system should put out when hot under pressure if the level is high enough a small amount into the puke tank, then yes when cold suck some back in...if you have not installed say a thermostat upside down ...and yours may yes be due to be changed now with the cars age...springs...the cap and thermostat age....good luck....
http://www.carparts.com/classroom/coolingsystem.htm
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 11-12-2017, 08:41 AM   #4
Spurshot
Drives: 2014 2SS blue
Sounds like maybe the radiator cap is a problem.
Spurshot is offline   Reply With Quote
Old 11-12-2017, 12:10 PM   #5
JOURDAN
Flushed three times, new therm, new cap, new heater core, new hoses.
Oil heater delete, block pluged, pressure tested.
Leak down > Excellent, compression > Excellent
Cooling system acts perfect - zero observed problems - except always pressure in system
The only thing I did not do is vacuum fill the cooling system, I have ordered the proper equipment, and may try that next.
I was starting to wonder if trapped air could somehow gas off and create residual pressure after cooling cycle.
Old 11-12-2017, 12:57 PM   #6
JOURDAN
Well.... after fighting this pressure for over a week, this morning the system had zero pressure.
The coolant bottle is one notch from FULL and the radiator is about 2 quarts low.
So.... I have added 1 quart, its about 1" from fill neck now - NOT FULL.
My guess is it will purge that quart into my reservoir bottle once hot.
Anyway what great news, something odd is going on but I do not think its catastrophic, something simple at this point, hoping.
Update soon
Old 11-12-2017, 01:06 PM   #7
JOURDAN
So I ask.
What is the coolant level in YOUR 6.2 Camaro radiator WHEN ICE COLD?
Could someone please look in theirs and see if the coolant is at top or low near fins.
Thanks
Old 11-12-2017, 01:41 PM   #8
JOURDAN
Update:
it did not purge the 1 quart of coolant yet, brought it up to 210 degrees at idle for about 20 minutes.
Upper rad hose is HOT
Lower rad hose COLD
Old 11-12-2017, 02:05 PM   #9
DonM
This is my 3rd Camaro
DonM's Avatar
Drives: All black '13 LS / Darth Camaro
Don M
DonM is offline   Reply With Quote
Old 11-12-2017, 02:58 PM   #10
JOURDAN
Well... as it turns out the temp sensor is in the head and there is a huge discrepancy between its reading and the actual temp at the thermostat.
So it can read 210 and not have popped a 190 thermostat yet.
So after driving for a few miles the thermostat opened and the system did not purge the quart I added this morning.
I am becoming very hopeful this is just a matter of air trapped in system manifesting in odd ways.
I now believe if you don't vacuum fill this particular cooling system, your screwed tell it sorts its self out. fingers crossed.
tomorrow morning hopefully I don't have pressure and I can attempt to add the last quart of coolant without it puking it out.
BUT, that would still beg the question... WHY doesn't pull its own coolant from the reservoir... oh well.
Old 11-12-2017, 03:39 PM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Just got back from a drive, or I would check right now. After it cools completely, I will check the radiator level. I've topped off at the overflow, but actually have never cracked open the radiator. If the system is full, the pull as it cools should be minimal from the overflow to the radiator, and vice versa, the push into the overflow from the radiator should be less than a pint or two I would imagine....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 11-12-2017, 03:46 PM   #12
Spurshot
Thanks in advance!!
I think your problem is the system is not properly filled. A coolant recovery system should have a full radiator. Right to the tippy top and then some.
https://www.howacarworks.com/cooling...cooling-system
Old 11-12-2017, 03:55 PM   #13
DonM
DonM's Avatar
With my recent questioning of my temp sensor reading 220* in stop & go traffic (once), I did check my fluid level in the radiator. While the recovery tank read on the low end of the stick when hot, the radiator itself was filled to the brim when cold ... maybe I need to recheck the overflow when cold and add a bit there.
Edited to add: When I get my flush done, should I make sure they refill the system using a vacuum machine and not just a "drain, flush & fill?"
Don M
Old 11-12-2017, 04:21 PM   #14
JOURDAN
That's the ways its looking, I think futile any other way unless you torture yourself for weeks trying figure out whats happening ...lol
