05-29-2015, 09:24 PM | #1 |
2018 HBM ZL1 A10
Drives: 2018 HBM A10 ZL1, 2014 AG 2SS 1LE Join Date: Feb 2015
Launch
When y'all go into launch control on your 2014 1Le what is the set RPM mine is 5200
05-29-2015, 09:52 PM | #2 |
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE Join Date: Nov 2013
Have not had the balls to try it yet! Especially after that guy planted that corvette into the trees using launch mode. LOL
Supposed to be 4400 RPM I thought |
05-29-2015, 09:57 PM | #3 |
Too low an RPM to be useful at the track. Wish it were tunable.
"Democracy Dies in Darkness" |
05-30-2015, 04:28 AM | #4 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I tried it once on hot, sticky tires, no suspension mods. It wheel hopped and the ring & pinion did not like it, they whine now. Never again!
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
05-30-2015, 06:38 AM | #5 |
Tri-County Camaro SWFL
My 13 is set at 4400, I used it probably 10 times. The car either bogs down or the tires spin bad. Only 1 time did it actually work and it went like a bat out of hell. But its far too inconsistent. I tried it recently (1st time since new Michelin PSS tires) all I could smell is clutch.
My .02, launch it your self and don't use it at a drag strip.
05-30-2015, 09:22 AM | #6 | ||
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
The only time launch control is really any good is with a dual-clutch transmission. On a manual, it's just that -- MANUAL.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
05-30-2015, 05:28 PM | #7 |
2018 HBM ZL1 A10
Any 2014 launches?? Thanks to all that answered
05-30-2015, 05:30 PM | #8 |
2018 HBM ZL1 A10
Shouldn't wheel hop in comp mode...
05-30-2015, 07:35 PM | #9 |
Drives: Synergy Green SS Camaro 6 speed Join Date: Sep 2014
its in the 4k rpm area. if yours is going to 5200 then you arent pressing the gas down fast enough
Synergy Green Camaro SS LS3 TH400, Stock Ported heads, Night Fury cam 4600 Circle D stall. 3.91 gears and rotofab intake, obx headers,
06-18-2015, 05:01 PM | #10 | |
Drives: '14 ZL1 'Vert - Black, #742 Join Date: Sep 2014
I've used it a number of times in my '14 with no problems at all. That said I have had varying results. Even though it seems like it should be a no brainer, the speed in which you let out the clutch pedal please a big role in results. You should not be dumping the clutch, you need to let off the clutch at about the same speed you'd use for a normal start. |
06-21-2015, 08:51 PM | #11 |
Drives: 2014 Camaro SS Join Date: Apr 2015
Crissis said it perfect .... Use launch control but don't dump the clutch or you're asking for trouble. Ease out of it and let it slip a little .
