08-19-2015, 09:21 AM | #1 |
Drives: 16' RedHot2 6MT SS Join Date: Aug 2015
Factory License plate on 14' Camaro
My dealer installed the OEM license plate holder for the front bumper, but i am wanting to take it off. I cant quite figure out how it comes off, or if it leaves any holes behind after removal.....It looks like it is clipped into the grill somehow, and then maybe riveted on there? Cant stand the look of the front plate, i would like to build/buy something that mounts to the factory towhook spot.
Has anyone successfully removed the OEM plate holder on a 14/15 1LE to see if anything is left behind? Thanks in advance, i tried searching but most threads are about aftermarket options not the OEM. |
08-19-2015, 09:36 AM | #2 | |
Drives: 2016 1SS Join Date: Apr 2012
Hope this helps you. Thank you, Ricardo |
08-19-2015, 10:10 AM | #3 |
damn the luck, i cant believe they actually drill into the bumper. :( any idea how small the holes are? looking at the rivets, it looks like they would be where the black plastic grill part is. i might could get something to fill those in like a small black plastic plug
08-19-2015, 10:33 AM | #4 |
Drives: 2001 2500HD Join Date: Aug 2014
Missouri requires a front plate anyway, so it could be worse.
2001 ECSB 2500HD
08-25-2015, 05:15 PM | #5 |
Agreed, mine looks like its screwed into the bottom black mesh piece, not the actual red painted bumper.
'14 ss here. |
08-25-2015, 05:23 PM | #6 |
Drives: 2014 1SS 1LE Join Date: Jul 2015
Someone had tried taking mine off before I bought it and made a mess of it. I just replaced the whole lower grill with a factory piece. Cost me $60
08-25-2015, 09:05 PM | #7 |
Mistress of the dark
check with the body shop, they installed it. cannot believe they won't help
08-25-2015, 09:16 PM | #8 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
I double sided taped mine on .. No holes
08-25-2015, 09:52 PM | #9 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2013
It's riveted to the bottom grille piece the holes will be there...not the bumper. I drilled my rivets out with a step bit. At first I got some plastic plugs from lowes but that looked like doo doo. So I priced the bottom piece new from the dealer and it was like 50 bucks. I ordered it and replaced it then got a show and go plate holder.
08-26-2015, 12:01 AM | #10 |
Drives: '04 Z06, '14BMW M235i, '15 SS/1LE Join Date: Feb 2014
I bought at $5 flat bracket from an auto parts store and zip tied the bracket. No holes and it doesn't touch any part of the paint. Last edited by homewrecker; 08-26-2015 at 12:13 AM. |
08-26-2015, 06:49 AM | #11 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
That will be my option if it ever comes to that, I just don't have one on the front, but I live in NY
UPSTATE C5 MEMBER
08-26-2015, 10:35 AM | #12 | |
08-26-2015, 10:11 PM | #13 |
08-27-2015, 01:18 PM | #14 |
