05-11-2015, 05:11 AM | #1 |
Drives: 1995 Camaro Z28 Join Date: May 2015
18"x9.5rim. What size tires?
First post guys and new to the camaro family. I just bought a 1995 red Z28 and it's got 235-55-16 tires on it. Im wanting to put the C6 Z06 rims that are 18"x9.5". I've saw a lot of people saying 275-35-18 tires for replacing a 245-55-16 tire. The 285-35-18 seem to be more of the same as originals. Will they fit all 4 corners? Thank you.
05-11-2015, 01:18 PM | #2 |
Somebody's got to have 18" wheels. What size tires do you run?
05-11-2015, 07:03 PM | #3 |
Drives: 2013 ram 2500 Join Date: Oct 2014
The 285 is the better choice, but they are harder to find. Look at tire manufacturer websites, and compare the overall diameter to that of a 275/40/17. The 285 is only 3/8" wider, and depending on the exact tire, maybe not even that much. The 275/40/17 is a sure fit on these cars, so compare to that.
Buuuttt... Either the 275/35/18 or 285/35/18 will work just fine, so choose which ever is available in the tires you want. |
05-11-2015, 07:28 PM | #4 |
Thank you.
05-12-2015, 10:21 AM | #5 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
I swap to a 245/40/18 drag radial on the rear for the track, it seems to look good, but there is room to go bigger. I still run the factory 16's all the time on the front, so I can't really say how they would work up there.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
05-12-2015, 11:45 AM | #6 |
Drives: 1996 Z28/SS, 2013 ZL1 Join Date: Jan 2015
They will fit the rear and should fit the front, but I'm running 18x10's with 275/35/18 front and 295/35/18 rear.
13 Camaro ZL1 IOM #3976
96 SS Camaro #1664, 04 2500 Dirtymax ZL1 Current Mods: KOOKS 2" w/orp, BTR Stage 3 Cam, LPE 2.55, LPE 9.1, ATI Damper, LPE Isolator Coupling, LPE CAI, Ported TB/Snout/Blower, JMS BAP, ID-850, 160 T, Ron Davis HX, D3 Reservoir, Elite Eng CC Gen2... |
05-13-2015, 07:27 AM | #7 |
Drives: 2011 Camaro 2LT, 68 Camaro RS Join Date: May 2010
I ran 275/35/18 on all four corners of my WS6. The car was lowered 1.5 inches...no problems except for hard cornering at speed. If you're not lowered, not a problem.
2011 Black/Inferno 2LT. Inferno Brembos, MRT 2.0, Vararam, BBK LTs, RX Catch Can, VMAX ICE-olator, VMAX P/P Throttle Body, Monster clutch, MGW Shifter, OverKill Tuned.
