#Camaro6
AWE Tuning
Old 04-21-2024, 08:53 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Went to the drag strip today...
Got to test out these Nitto 555R2's. 305/35R20
Temperature Range: 45-50 degrees F
DA Range: -280 to 300
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
FlukeSS is offline   Reply With Quote
Old 04-21-2024, 10:37 PM   #2
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
^^^ Sounds very nice!
KC64 is offline   Reply With Quote
Old 04-26-2024, 12:28 PM   #3
wnta1ss
Drives: 2017 Camaro 1SS
Hmm, no feedback yet on the runs? IMO a 1.86 short time on drag radials, with ECM/TCM tune and quite a bit more hp than stock, was quite noticeably slower than I'd expect. Did not sound like you spun to get that 60? Not sure what is happening, but I would suggest trying launch from idle next time, and see if it's any better.
Since you were data logging, you probably already know this, but your current TCM tune had the WOT shifts at too low an rpm for best performance. Looking at your 11.6 run, the shift was way too early for the 1>2, too early for the 2>3, and still a little early for the 3>4 and 4>5. Your dyno chart had peak hp around 6200, and therefore, you could try for about 6700 for your shifts and see what it does. This is drag racer knowledge for many years, shifting around 500rpm after the hp peak for best performance. Might want even more than 6700 in this thing to be honest, but that would be a decent start IMO.
wnta1ss is offline   Reply With Quote
Old 04-26-2024, 03:38 PM   #4
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I know the btr cam is going to lose a little torque down low from a stock cam but it kind of seems like torque management is still limiting torque on the initial hit, shift rpm does seem low as well. The Mustang dyno numbers don’t really match the et and mph imo. Why such cold spark plugs? Those are what I run on my turbo setup now. My car is lighter being an LT1 vs a 2SS and I am on a drag pack front and rear but my car went a lot quicker and faster with less. https://youtu.be/lUEOPs5Qzxw?si=lE2jJS6y9ovm4E79
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels
1.45 4.01 6.07@120.74 9.28@153.43
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild
jlaudio11 is offline   Reply With Quote
Old 04-26-2024, 07:05 PM   #5
FlukeSS
FlukeSS's Avatar
Stock Torque Converter. Laynlow15 said the cam may actually slow down my 60 ft and to try to launch from idle instead of brake torqueing to flash the torque converter. My tuner also said I'm using too low of a tire pressure as well that I want to be about 20 psi warm. Just to be clear I was told the cam tops out at 7000 rpm. I know subsequent shifts are about 6500. But I do notice what you said that the shifts 1st to 2nd and 2nd to 3rd are lower. I'll ask my tuner about it see what he says. Also, my tuner is using an older version of HP Tuners and couldn't open my logs to check the tune. I have to do a new set of logs on his version of HP Tuners, but I do intend on having the tuner check the tune to make sure it is running the way he believes it should. But as I said to JLAudio: I'm still new to this so maybe I am just not experienced enough to where I should be pulling the numbers other people get with a similar or worse setup. My fastest time on street tires Eagle SC3's was 11.9, which while it is below 12, it took me a long time to get there, and that was after adding the LT2 and TB. I know its not as good as some people with less. Although to be fair I'm not a small guy either. 240lbs not like other people you see in youtube videos whom weigh maybe 50-70lbs less than me.
Also, my front tire size is too small. 275/30R20 so it is effecting my Traction Control, ABS, and power steering. Just picked up some 285/35R20's for the front and readjusted the tire size in the ECM. And of course I'm not on a full drag pack with skinnies up front either. You also have drag slicks. I am not running slicks. 555R2's are dot compliant street drag radials. Think MT street SS but slightly worse and better in water. Looks like you also have a 17" wheel maybe? So you have more meat on the back end in terms of tire wrinkle on launch. And lastly based on your signature history, it looks like you probably are just more experienced at drag racing than I am. I have maybe 40 runs under my belt in the last 2 years.
Going this coming Sunday, will try again see if anything changes.
Old 04-26-2024, 08:07 PM   #6
FlukeSS
FlukeSS's Avatar
@wnta1ss and @jlaudio11
Please don't take what I said as me making excuses or being angry or retaliatory. I appreciate the advice when given. I am just not experienced enough to discount anything anyone says is the way I look at it.
I've just been talking to laynlow15 a lot about my car so he knows more about what is going on with it than anyone on here, and he has said the same things you guys have said. So it is at least common consensus that I should be faster but for some reason I am not.
Just haven't figured out if I am the problem, or if its the car yet. I assume its not the car its me, because I just don't know that much about drag performance other than numbers I see. I assume its a me problem, unless one of you guys suggest there might be some play left in the car still. And what I can do to remedy the issue either way.
Old 04-26-2024, 09:17 PM   #7
jlaudio11
jlaudio11's Avatar
Atleast you have the right attitude about it all. With launching, what worked the best for me and what you saw in those videos was holding rpms up around 900-1000 rpm and then smashing it. You’ll get some flash out of the converter like launching from idle, I just felt like there was a little bit of a delay that cost et going from absolute idle. See what your tuner thinks but there are others of us here that could look at your log and give feedback. That can get tricky where you’re almost questioning your tuner and everybody will have different possible suggestions, it could get messy basically.
'20 Camaro LT1
Old 04-27-2024, 07:57 AM   #8
wnta1ss
I was trying to help and from your response, I believe you do understand that. I think you can try altering your technique and see if times improve, but the timeslip tells me the car itself is not right, so there's only so much you can do. For some perspective, with a similar-size driver at the time, I ran my partial-bolt-on A8 SS in street trim (old 275 PS4S tires on back). Partial-bolt-on means intake manifold/zr1 tb/cai/flex fuel/tuning ecm and tcm/scoop. Similar DA to your run, went 11.56@122, spinning all the way through first (1.91 short) and even hit the rev limiter in 1st. Now my street-trim was behind your slip by .05 at the 60 yet catches up and beats the ET by .11sec? That points to a problem with your tune as far as I'm concerned. Yours should easily have 50rwhp more than mine did, therefore it should be pulling harder. I agree with jlaudio11 that your tcm tune *might not* have the torque tables fixed like they should be. Can you read the tune? I know with my 2017 T87a, you could only 'read' a generic stock TCM tune from HPT back in the day (not read the actual modded TCM tune in the car), not sure what happens with the T93? However you can read the ECM tune, is that correct? There are some things in the ECM tune which should be checked as part of the shift-point adjustments. I have personally seen a dyno-tuned car, by a good-reputation guy, and it turns out he did not correct the EOT table for the rev limiter. Meaning the 6800rpm he had for extreme cutoff was over-ridden by the stock 6600rpm figure in the EOT table, and the limiter engaged before desired. Having the throttle close during a dragstrip run is counter productive.
As far as the cam giving a softer leave, I have seen video of a Stage 3 cam going 1.72 short on the stock SS A10 torque converter. Since your Stage 1 *should* have less of a torque loss way down low than a Stage 3, I would think that yours should be a little bit snappier at the hit than his was?
Old 04-27-2024, 12:30 PM   #9
OB0001
2018 SS A8 11.85@117.06
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
ran a 11.85 @117 on run flats last summer @ Milan run flats LT2 intake some bolt on's tune E85. wheel slip all the way down the track
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake
OB0001 is offline   Reply With Quote
Old 04-27-2024, 01:06 PM   #10
FlukeSS
FlukeSS's Avatar
I was just saying what I said might be misconstrued as me not being receptive I am, and I take what everyone says to heart. I just didn't want my response to be mistaken for being ungrateful.
My tuner said he locks the tune, so I wouldn't be able to see the trans tuning he did. And I don't know enough about HP Tuners to dabble much beyond changing tire size.
1.86 is the best 60ft I've had thus far, before the cam and rebuild I was at 1.91+
I am trying to keep myself somewhat grounded and figure that even though some people see 0.5 sec off their times with drag radials that what works for one person can be different for another. I was expecting a 11.7 which I got, and last time at the drag strip some indication of consistency since I ran a 11.7 and 11.67 back to back. I figure the rest is me being inexperienced trying different things to drop the number more. I think it might rain tomorrow so I wont' be able to try new things tomorrow but maybe next wednesday I'll get the chance.
I also just got the front tires replaced, so no indications of TC, ABS or Power steering issues now. Yet.
Old 04-27-2024, 01:08 PM   #11
FlukeSS
FlukeSS's Avatar
I was at 11.900 before the engine rebuild & cam on Eagle SC3 street tires no slip but I was also first one on a newly prepped track at that time.
Old 04-27-2024, 01:33 PM   #12
FlukeSS
FlukeSS's Avatar
Ya, I don't like questioning the tuner, because I don't want it to sound like I am being critical of them. I've seen the work Shane does he's a good tuner, I feel like every time I ask a question to a tuner they might get upset, and I'm trying to avoid that. I feel like I am trying to avoid sounding needy, but then again I did pay him $1600 for the tune as well, and I just want to make sure the tune is good.
Old 04-27-2024, 01:37 PM   #13
FlukeSS
FlukeSS's Avatar
I do have his tune file on hand, as it is currently on my car.
I can open it in HP tuners, but he said I wouldn't be able to see the trans tuning.
This is all I see under Transmission
This is what I see under Torque Management
I do find this interesting though: I believe I have a 4 degree variable cam? But it looks like it is set to 2 degrees? The only time I went to the tuner was drivability at low speed was rough and the engine would stall out at like stop lights or if I was in a gas station and/or parking lot. So I am not sure if that has any relevance here?
Old 04-27-2024, 02:39 PM   #14
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Based on this screenshot, your transmission control module (TCM) isn't unlocked, and you only see the settings that are stored in the ECM. The A10 will not be tunable until you get it unlocked.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
