04-18-2016, 08:24 AM | #1 |
Banned
Booooom connecting rod wanted a divorce
Plays TAPS
https://vimeo.com/163254242 SLP supercharged 2013 SS/RS 1LE VR Full front half protected by Xpel PPF Instagram:@Failshift 565hp/560tq @8.6psi 1LE Owners Group: https://www.facebook.com/groups/559684050767758/ |
04-18-2016, 10:26 AM | #2 |
Too much is never enough!
How did that happen? Didn't you just buy that car?
04-18-2016, 10:28 AM | #3 |
Banned
No I'm The original owner. But I did just put the blower on. Very mild setup. Should've had WAYYYY more than enough fuel. Just got a weak engine from factory I suppose. 3/4 throttle. 6,000 rpm. Rooommmmmmm pop pop pop pop. Knock knock knock knock........ |
04-18-2016, 10:29 AM | #4 |
what was your AFR?
04-18-2016, 10:31 AM | #5 |
Banned
I wasn't looking at it at the time.
04-18-2016, 10:33 AM | #6 |
That's why, whenever I get something done to my car, I always try to data log it. Its just too hard to look at all those gauges when your holding on to the car.
Sorry to hear about this man, do what I did and forge your internals. Then turn up your boost!
04-18-2016, 10:36 AM | #7 | |
Banned
Well I got it back the day before from ADM. Had to go back because it was running super rich. And my o2 sensors were bad. So he fixed all that. Ran it in dyno. Double check everything. He even ran it once more when I picked it up just to watch them again. I'm praying it's valvetrain collapsed lifter. But highly unlikely. Engine options are forged 417 shortblock he can get me for $5k. Lsx376 for $7600 is what I'm Kind of leaning towards. That 50k warranty is catching my eye. |
04-18-2016, 10:38 AM | #8 |
IF ADM had it, then I'm sure your AFR was good. Honestly there is no need to go LSX, unless your planning on some 4 digit horsepower numbers. Hell even at that a built LS3 will meet your needs man. IMO do the forged LS3 and put the money to something else.
04-18-2016, 10:40 AM | #9 | |
Banned
Well I'm hesitant on that because that 417 will push a lot of power. I don't want to go over 600isj wheel. Then I'm pushing the clutch. And the fuel system |
04-18-2016, 10:43 AM | #10 |
It will only push as much power as the boost you put to it, if you leave your boost alone, you will gain some power, but not enough to stress your components. IMO
BTW It could be valvetrain like you were saying, that really don't sound 100 percent like a rod.
04-18-2016, 10:46 AM | #11 | |
Banned
If it it's valvetrain I'll replace the whole thing. LPE CNC heads. Lifters. Can. Trunions. Oil pumps. Valves. Springs. Pushrods. Ect and feel blessed to only spend that much |
04-18-2016, 10:53 AM | #12 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
You know it's bad when...
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 04-18-2016 at 11:29 AM. |
04-18-2016, 10:58 AM | #13 |
Hes still beating that stang!
04-18-2016, 10:59 AM | #14 |
Banned
