Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 04-16-2014, 05:37 PM   #1
redleader
redleader
Drives: 2010
Noise, Diff ?
So, I'm sure my Camaro never made this road-noise like sound before my journey to SantaPod and back ...
It's not a whine, or a buzz, more of a tyre tread hum ... so I'm thinking as I'm at almost 20k my Diff Oil needs changing?
redleader is offline   Reply With Quote
Old 04-16-2014, 05:56 PM   #2
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
Oil certainly should be changed, but dirty oil won't cause noise. You may have a bearing going bad though.
Bye bye, Bumblebee!
Old 04-17-2014, 02:34 AM   #3
redleader
redleader
Drives: 2010
Thanks strych9,
After <20,000 miles over 4 years driving like a Grandad I'm surprised it could be a bearing.
I had 1.2" drop spring installed 3 months ago, so maybe they need a check now they are bedded in, it does groan and clinch a wee bit in reverse after that :-(
For the Diff Oil I've only bought 1qt as I was just going to do a drain and fill, do I really need more to do it, flush it, 3 times like the service manual suggests?
Cheers :-)
Old 04-18-2014, 01:00 AM   #4
RickGM
RickGM's Avatar
Drives: 2013 SS V8 L99 Magnusson Heartbeat
If it was a highly tuned F1 car that was being thrashed to its limit of self destruction and which required every last bit of perfection for ultimate competitive performance then I'd probably agree. On the other hand ..... Sounds like b*llox to me.
UK Camaro Owner. One of a few.
RickGM is offline   Reply With Quote
Old 04-18-2014, 02:07 AM   #5
jules1200
Drives: Delorean DMC12, Camaro SS
Correct, I was 'in the trade' for 25 yrs & have NEVER known anyone EVER change diff oil, other than when doing some other maintenance.
jules1200 is offline   Reply With Quote
Old 05-10-2014, 06:28 AM   #6
scites
Drives: 2010 camaro SS/RS
James , id j ust drain and fill it, UNLESS you see a shit ton of wear metal/gundge come out then try to flush it..Buy yourself a turkey baster or you are going to waist a lot of fluid..
Tom
scites is offline   Reply With Quote
Old 05-10-2014, 07:15 AM   #7
redleader
redleader
Drives: 2010
Noise, Diff ?
Thank you!
Answers my other Post reply to you too :-)
