08-16-2011, 10:02 PM | #1 |
Drag Racing FAQ's
Noticed there are quite a few of us new drag racers on this site and wanted to start a thread that we can post questions and have them answered by more experienced racers.
08-16-2011, 10:12 PM | #2 |
1st. Question:
My 2010 Camaro has Vortech V-3 supercharger / GT-9 Cam / AR headers / Borla Cat-backs / Torque Converter / larger sway bar / dyno'd at 609 RWHP I'm running Nitto drag radials on rear at 20 PSI while racing. My average time at Fontana is just 12.20 ! I see other guys on here with just as much RWHP getting mid 11's per their post. Shouldn't I be getting lower ? What am I missing ?? Just ordered 17" drag wheels 5-front / 10-rear I'm told this will help with "Rotating Mass" Any thoughts/ideas are appreciated. Spent alot of $$ to just be getting low 12's . |
08-16-2011, 10:15 PM | #3 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
moved to the drag racing subforum
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
08-16-2011, 10:27 PM | #4 | |
Drives: 2010 IOM SS Join Date: Aug 2009
08-16-2011, 10:40 PM | #5 |
Here ya go.
08-16-2011, 10:42 PM | #6 |
Here's another
08-16-2011, 11:20 PM | #7 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Try the tires at about 15psi. That's not good mph for your rwhp at all. You should be trapping over 120 mph. What your d.a.? Elevation? Temp?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
08-16-2011, 11:24 PM | #8 |
To put it in perspective, my 3rd gen, which weighed a certified 3400lbs with me in it, made 407rwhp and ran 11.40's at 122mph. That's with a 1.8 60ft in 90-95 degree weather. This is at sea level. Add 600 lbs to the car and it should slow down about 6mph, which would be 115-116mph and 200hp less. Maybe my math is wrong somewhere, but something isn't adding up correctly to me?
08-16-2011, 11:31 PM | #9 |
08-16-2011, 11:34 PM | #10 |
Once I get Drag wheels I'll be running MT skinny's and slicks on the rear. Hopefully that will help.
08-16-2011, 11:50 PM | #11 |
Man, with 609hp, even tho you have a huge load to haul you should be a bit faster. That Sux dude, I'm not sure what the cause is. You should be damn near in the 10's with that kind of power. The 60ft isn't that bad, but isn't that great either. The main thing I look at is the trap speed when I'm looking at a time slip, that tells the tale. With your trap speed, you have an 11.80 car. It should be a 10.80 car. If you get your 60ft down to a 1.6, you'll turn that 11.80. What gear are you going through the traps in? Are you holding it out at the end and it quits pulling or are you just shifting into another gear?
08-17-2011, 09:20 AM | #12 |
Drives: ZL1 Camaro Join Date: Feb 2009
what stall are you running?
08-17-2011, 10:16 AM | #13 | |||
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
Run #1 RT ........... .128 60' ......... 1.863 330 ........ 5.212 1/8 ........ 7.918 MPH ....... 91.16 1000 ..... 10.229 1/4 ....... 12.172 MPH ...... 117.58 Run #2 RT .......... -.012 60' ......... 1.877 330 ........ 5.225 1/8 ........ 7.931 MPH ....... 91.17 1000 ..... 10.241 1/4 ....... 12.180 MPH ...... 118.02 Full weight making about 460rwhp on the stock 20" wheels with Nitto DR's. The tranny was hanging up on every shift. These were the very first runs after the pistons, heads, cam, headers, cai, tune etc. went in. At a later track event I ran 12.0 and think it has an 11 easy now that a rebuilt tranny is going in.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
08-17-2011, 11:02 AM | #14 |
I see all these high hp cars with dismal 1/4 mile times and so so trap speed. What's the deal? do these motors make no midrange torque? Is it all just top end hp? Maybe the heads and or camshafts people run are too big. Making big peak hp doesn't mean squat if if you have no torque. I just don't get it? If the op is running 12.20 with 608rwhp, he'll need 950rwhp to get into the 10's. I just don't get it.
Thread Tools | |
Similar Threads | ||||
Drag Racing comes back to long island with a catch | Driveshaftshop | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 01-07-2011 12:57 PM |
Lowering springs and drag racing (bad idea?) | SGOS252382 | Dragstrip and Launch Techniques Discussion | 26 | 04-16-2010 02:11 AM |
Drag Racing | Adam@ST | USA - California | 6 | 01-24-2010 09:24 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
