06-15-2010, 05:01 AM | #1 |
windshield humidity problems
Does anyone else have problems with windshield humidty? I have a spot (about 2"x6") that appears when the A/C is on for the vents and not the defroster?? Mine seems to do it very frequently.
Some people know the cost of everything and the value of nothing
06-15-2010, 05:18 AM | #2 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
there is some residual airflow that will blow up thru the defroster vent. happens on most every car given the right temp/humidity differences
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
06-15-2010, 07:13 AM | #3 |
Drives: Red 2010 LT1 RS Join Date: Aug 2009
I've noticed the same thing, but you just have to play with the temp control a bit to find the right temp to take that away but still keep you comfortable.
Mine [8/10/2009] - 1LT RS / Victory Red / Black Interior |
06-15-2010, 07:17 AM | #4 |
Yeah, it's quite annoying, especially when backing out of the garage. It takes quite a few minutes to clear it up. I have found the best thing to do is to run the windshield wipers.
06-15-2010, 07:17 AM | #5 |
Drives: 2010 Camaro 2SS RJT Join Date: Jul 2009
I had the same problem and was told also "all cars do that" well they don't. I have owned many cars trucks whatever in the past and none were as bad as this Camaro. Most of them didn't do it at all. As said the defrost vent never fully closes, I have no idea why this would be a good thing or necessary. Pretty much the only solution is to add in just a touch of heat and that seems to take care of it. Doesn't take much just a few clicks.
06-15-2010, 07:19 AM | #6 |
Drives: Born:18 Sept 2009 #47903 Join Date: Oct 2009
Same Problem. Really bugs me while driving...
2010 Camaro 2SS________________________________________Litho#140
06-15-2010, 07:21 AM | #7 |
Boosted Moderator
This problem will go away as the initial excitement of driving the Camaro eases... Slow your breathing and relax...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
06-15-2010, 07:21 AM | #8 |
Drives: Love the one you're with Join Date: Sep 2009
No every car doesn't do it. I have four other cars and trucks and this is the only one that does it for me. AS others have said above though adding a touch of heat does the trick.
06-15-2010, 07:27 AM | #9 |
My dad's 1993 Cavalier used to do the same thing. There was a certain temperature where you would run the defroster with the AC on, and it would haze up outside the window and you would have to run the wipers. if you turn off the defroster, the windows inside would fog up.
I've had this happen in my Camaro. I'm pretty sure it has happened in my Camry as well. It is odd that you have to run the wipers to get rid of that, but it beats not being able to see because of the haze on the inside of the windows.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
06-15-2010, 10:21 AM | #10 |
Cracker
Drives: 2010 2LT/RS Summit White/Beige Join Date: May 2010
My Kia did this also. I wouldn't say it's a "problem", it's fairly common. It's not like it's a defect or anything.
2010 Camaro | 2LT | RS | Summit White | Beige Interior | Born: 5/10/10 | Purchased 5/28/10
06-15-2010, 10:26 AM | #11 | |
Comic Curmudgeon
Drives: 2010 Camaro 2SS-2010 VW CC Sport Join Date: Mar 2008
If it is on the outside, that's normal. It is from the cold air cooling the windshield and forming a cold spot on the glas. This causes the outside humidity to condens, forming moisture on the windshield. Happens on every car I own. Normal. To stop it, I increase the temperature setting on the AC.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name. |
06-15-2010, 10:58 AM | #12 |
It's on the outside, the point is when turn your A/C to the "Vent" position, you would like it to be ONLY vents. No, not a defect just a poorly designed duct system.
06-15-2010, 11:22 AM | #13 |
Comic Curmudgeon
My 98 Camaro did it. So did my Acura RL,my Grand Prix, My Impala, my 95 Camaro.
Not a design flaw. It is basic thermo dynamics. Cold air on a concentrated area causes condensation. Will happen on almost any car or truck.
Similar Threads | ||||
1st and 2nd gear problems. 1SS 6M | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 10-29-2019 12:22 PM |
Automatic Transmission Problems | Kyzer | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 30 | 07-13-2016 06:26 PM |
OEM windshield or aftermarket for replacement | zlwebb | 5th Gen Camaro SS LS LT General Discussions | 15 | 05-10-2012 03:44 PM |
Windshield Wiper Post Cover | SWING | USA - Texas | 26 | 09-26-2011 01:14 PM |
Long Problem(s) GM techs or someone needed here... | xpanda305x | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 37 | 07-04-2010 02:00 PM |
