03-27-2011, 11:23 AM | #1 |
Still love daily drivin'
Drives: Built '10 IBM 2SS; '15 Black Z/28 Join Date: May 2009
Recommendations on a Blower cam after ported heads
So....lots of great reading on here and the FI threads. I'm going with the Maggie 2300 and gonna have Scoggin Dickey port the heads in the process.
Now I'm trying to get my head around a few good cam options to maximize those two. Porting intakes to ~ 279 and exhaust to ~ 99; yields ~ 350cfm intake and 230cfm exhaust at .600 lift. Right now not intending to increase combustion chamber (unless drop in compression = bottom end longevity with the boost) Currently 400rwhp to the wheels with CAI, Headers, HF cats and exhaust on an M6 Tranny. Target is a well-mannered 600rwhp (until punched). For ~7 PSI with the increased head flow, is the more stable tune going to come from more duration, or more lift (more mild cam at .650; or more aggressive at .600)? Thoughts?
03-27-2011, 03:31 PM | #2 | |
The stick man
Drives: 2004 GTO - C5 'vert - SRX Join Date: Jul 2006
Get with Mike at New Era Performance Parts on this. Ed
PONY WARS |
03-28-2011, 01:20 PM | #3 |
Thx. In Afghanistan...communication is a bit of a challenge outside of email or here. Is he on here?
03-30-2011, 10:51 AM | #4 |
anyone else able to advise?
03-30-2011, 11:00 AM | #5 |
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
A BIG ONE!! Semper Fi Devil Dog!!!
2G1FS1EWXD9163847 |
03-30-2011, 11:28 AM | #6 | |
I have a magnacharged , dod delete, tci super harmonic balancer, ported scoggin dickey L92 heads, cammed w/comp single bolt cam 223/236 .610"/.608" 117+4 lsa from thunder racing, stock torque converter, runs and sounds great. You may like this pic, two Marines at the Hooters car show by my car in baton rouge. 11-29-09
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s. Last edited by klatterblast; 03-30-2011 at 12:20 PM. |
03-30-2011, 11:45 AM | #7 |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
PM Andy @ admperformance he pushes maggie/Cam equiped cars out the door daily like Candy.
Andy knows his stuff. |
03-31-2011, 07:29 AM | #8 | |
The stick man
^ Best way to contact Mike. ^ Thank you for your service.
PONY WARS |
03-31-2011, 08:44 AM | #9 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
Do you have an L99 or LS3? If and L99 consider a torque converter with the cam.
I have an L99 and I am having a blower cam installed right now. I went with the Livernois stage 2B blower cam and a Precision Industries Vigilante torque converter. This is not a monster cam because I want my car to have excellent street manners. I am also having Livernois port the heads on my car. |
04-02-2011, 01:00 PM | #10 |
All; thanks for the feedback!
Klatterblast....sounds like our builds will be similar... sending my heads to SD for porting before the cam/blower install. And you cam specs are close to what I was expecting...bit more LSA. I'm a M6, so not sure if that will matter too much on the LSA or not (i've read mixed info)--and yeah...love the pic! J-N-H and FTI, thx for the links...I'll check them out. I definitely want at little lope at idle... Darth...I'm really interested in what your idle turns out to be with the stage 2....that was my starting point (not sure if a Stage 3 would be too over the top outside of idle). Are you opening the combustion chamber any with the head work? Dropping the compression a bit can be good with blowers (though your L99 already has a slight head start over my LS3). Darth and K-Blast, pls share your RWHP when you have it! Thx again to all... (FTI....proud to serve...a calling, if you will!) Semper Fi, Stu
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
cam and heads are done | sspaul | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 02-03-2011 12:24 PM |
Ported & Polished L99 heads | SRT10KLLR | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 16 | 01-20-2011 04:06 PM |
Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 | D-Unit | Forced Induction - V8 | 12 | 07-29-2008 03:34 PM |
Parts from GM (cam and heads etc) | blackgloves | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 06-19-2008 10:48 PM |
