03-09-2014, 02:32 PM | #1 |
Drives: '01 Camaro SS 'Vert; '02 Camaro RS Join Date: Apr 2013
FS:93-02 Camaro/Firebird Various Parts
1. 93-02 Camaro/Firebird Front and rear sway bars removed from 01 Camaro SS and Energy Suspension poly bushings/endlinks, good shape - $150
2. 93-02 Camaro/Firebird Rear Swaybar - $30 In good shape, removed from a 2002 Camaro RS. 3. 93-02 Camaro/Firebird Front Pair of Swaybar Mounting Brackets - $18 4. 82-02 Camaro/Firebird Open Differential Carrier- OEM Series 3 - $45 OEM Series 3 10-Bolt Open Differential Carrier, 28 Spline, GM 7.5, from an '02 Camaro 3.8L. Bearings are in good shape with no pitting. This unit is in full working order and can work with or be made to work with '82-'02 Camaros or Firebirds. Please check your specific application. 5. 93-02 Camaro/Firebird OEM Rear Shocks - $28 '93-'02 Camaro/Firebird OEM de Carbon/Delphi Rear Shocks -- two pairs available, from 2001 Camaro SS (V8), or 2002 Camaro RS (V6). 6. 93-02 Camaro/Firebird Front Pair of Lower Control A-Arms - $78 93-02 Camaro/Firebird Front Lower Control A-Arms -- one pair available, from a 2002 Camaro. It is easier to replace bushings on a set that is already off the car, then just mount them! The price is for one pair, will separate if desired. 7. 93-02 Camaro/Firebird OEM Driveshaft, manufactured by AAM, recently replaced u-joints, removed from an 01 Camaro SS. - $85 Shipping from Illinois would be extra. Pictures available upon request. Thanks! Last edited by libertyforall; 07-20-2014 at 08:38 PM. Reason: added info |
07-20-2014, 08:38 PM | #2 |
*summer bump*
09-22-2014, 10:28 PM | #3 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
Never mind I found one....thx
