Old 03-31-2013, 11:00 AM   #1
actireman
Drives: 2011 denali hd2500
Lost reverse M6
Unbagged my car yesterday and went for a ride. Everything was fine until I got home. I did a burnout down my driveway (like I always do), and went to back up and the shifter would not go past 5th and 6th. The only way I could get reverse was to push real hard to get it. Any ideas? I checked fuses for related items. I couldn't find one that said reverse lock out.
actireman is offline   Reply With Quote
Old 03-31-2013, 11:20 AM   #2
16floz470ml
16floz470ml's Avatar
Drives: 2012 ZL1 GLJ MG9 WBP RTQ
Reverse Inhibit Description and Operation
The reverse inhibit solenoid is a safety feature which prevents an inadvertent shift into reverse at speeds above 5 km/h (3 mph). The system consist of the following components:
  • The powertrain control module (PCM).
  • The reverse inhibit solenoid.
With the ignition ON, battery voltage is supplied directly to the reverse inhibit solenoid. At forward speeds above 5 km/h (3 mph) the PCM opens the control circuit of the reverse inhibit solenoid. This de-energizes the solenoid and mechanically blocks the shift lever from going into the REVERSE position.
16floz470ml is offline   Reply With Quote
Old 04-01-2013, 12:28 PM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
It's the locout solenoid not getting voltage for sure. I am not sure which circuit powers it though. both the skip shift and the lockout soleniod look about he same down on the tranny.
make sure the connector is plugged in all the way.
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
