SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Engine Internals
Old 02-03-2014, 08:18 PM   #1
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Talking Driven/Joe Gibbs Racing Oils, Fluids, Cleaners and more! | In stock | JDP Motorsports
Hi Everyone!
JDP Motorsports is excited to offer and use Driven Joe Gibbs racing products! Many of you probably know them mostly for their break in oils which we also stock, but they also offer an LS specific oil for our LS engines!
Driven Racing Oil - LS30 High Zinc Synthetic 5W30 - Part # 02906
Designed for high performance LS series engines, LS30 reduces oil consumption by limiting oil vaporization and foaming. It utilizes advanced mPAO synthetic base oils to reduce valve train noise and to provide high temperature and high shear protection for GM LS based engines with and without variable valve timing. LS30 delivers industry leading shear stability and HTHS bearing oil film thickness. Ideal for LS-based crate engines and supercharged LS performance engines as well as any performance engine that calls for a 5W-30 viscosity. Viscosity typical of 5W-30.
Product Features:
  • High Temp High Shear Protection
  • Friction Reducing Additives
  • Meets Demands Of VVT System
  • Reduced Consumption Via PCV
  • Sold in quarts or by the case
  • FREE Shipping on orders over $100
$11.99 per Quart
Driven Racing Oil - BR30 Break-In Oil 5W30 Quart - Part # 01806
The same high Zinc and Phosphorus formula as our original break-in oil, now in an SAE 5W-30 viscosity for modern OEM rebuilds and hydraulic lifter engines. Provides excellent ring sealing. Does not require additional ZDDP additives. Good for full power pulls on the dyno, one night of racing or up to 400 miles on the street. Viscosity typical of 5W-30.
Product Features:
  • ZDDP-Fortified Cam Protection
  • Chemically Seals Piston Rings
  • Protects Bearings & Journals
  • Free Shipping on orders over $100
$9.49 per Quart
Driven Racing Oil - DT40 High Zinc Synthetic 5W40 Quart - Part # 02406
DT40 utilizes advanced synthetic base oils to provide high temperature and high shear protection for both turbocharged, and European sports car engines with and without variable valve timing. DT40 reduces oil consumption by limiting oil vaporization and foaming. Compatible with E85 and water/methanol injection. Viscosity typical of 5W40.
Product Features:
$11.99 per Quart
Driven Racing Oil - BR40 Break-In Oil 5W40 Quart - Part # 03706
The same high Zinc and Phosphorus formula as our original break-in oil, now in SAE 10W-40 viscosity. Well suited for classic muscle car, European sports car and motorcycle engines. Ideal for flat tappet and aggressive roller valve trains, as well as Ethanol- blended, pure Methanol and oxygenated race fuels. Does not require additional ZDDP additives. Good for dyno testing, one night of racing or up to 400 miles on the street. Viscosity typical of 10W-40.
Product Features:
$9.49 per Quart
Driven Racing Oil - Synchromesh Transmission Fluid Quart - Part # 04006
STF protects gears, bearings, and internal clutches in extreme heat environments. By reducing friction, heat, and wear, it improves shifting characteristics and lowers operating temperatures. Exceeds performance requirements for GM synchronized transmissions. STF features advanced synthetic base stocks, multifunctional performance additives, corrosion inhibitors, and a foam suppressor to provide excellent synchronizer performance and compatibility with yellow metals found in manual transaxles and transmissions. Recommended for manual transmissions that require automatic transmission fluids, multi-viscosity, or straight grade motor oils.
Product Features:
  • Protect gears, bearings, and internal clutches
  • Improves shifting characteristics
  • Exceeds GM performance requirements
  • Sold in quarts
Price $19.99
Driven Racing Oil - Power Steering Fluid Quart - Part # 01306
Featuring a fully synthetic formula that prevents steering fade by reducing temperature and delivering consistent steering response. Driven Racing Oil's power steering fluid offers exceptional low temperature flow to reduce initial drag on the pump and provides improved thermal stability for less pressure drop as temperatures rise. PSF provides high temperature foam resistance and low volatility for better cooling and improved steering precision. This fluid is ideal for all power steering systems from OEM to purpose built race steering systems. Good for road racing, autocross, off-road, rock-crawling, and circle track.
Product Features:
  • Delivers consistent steering response
  • Exceptional low temperature flow
  • Reduces initial drag on the pump
  • Fully synthetic formula provides improved thermal stability for less pressure drop as temperatures rise
  • Offers high temperature foam resistance for better cooling and improved steering precision
  • Sold in quarts
Price $19.99
Driven Racing Oil - Limited Slip Gear Oil 75W90 Quart - Part # 04230
Designed using the latest synthetic oil technology to provide consistent limited slip differential performance, the 75W90 gear oil is ideal for both clutch type and torsion type differentials. This competition proven formulation utilizes a proprietary additive package that reduces drag, resists foaming, and maintains its viscosity under extreme heat and high loads. It delivers outstanding performance in extreme environments like autocross, off-road trucks, UTVs, track day cars, and race vehicles. Exceeds the performance requirements of API GL-5. Recommended for limited slip differential applications. Viscosity typical of 75W90.
Product Features:
  • Reduce operating temperatures by more than 15 degrees Fahrenheit
  • Shear stable viscosity
  • Sold in quarts
$19.99 Per Quart
Driven Racing Oil - CSP Coolant System Protector - 50030
Featuring Driven Racing Oil coolant system protector designed to protect your engine block, cylinder heads, water pump and radiator from mineral deposits and corrosion by neutralizing minerals found in regular and well water preventing damage from hard water. CSP prevents corrosion in modern "orange" OAT coolants, traditional "green" anti-freeze and straight water. It also keeps engine coolant passages clean and lubricates water pumps
Note: Do not mix with other coolant additives.
Product Features:
  • Adds Corrosion Resistance to Modern “Orange” OAT Coolants
  • Better “Wetting” than Traditional Coolant Additives
  • Improves Engine Cooling by Improving Surface Wetting & Lower Surface Tension
  • Stops the Adverse Effect of Hard Water Better than the Leading Brand of Coolant Additives
  • Protects Against Rust & Corrosion Inside the Radiator, Water Pump & Cylinder Heads
  • Stabilizes Hard Water
$9.99 Per Bottle
Driven Racing Oil - Race Wax - Part # 50060
Featuring race wax that cleans and shines glass, chrome, paint, plastic, tires and vinyl and leaves a smooth, glossy finish that helps shed tire rubber, dirt and bugs. It's great for fiberglass cars, decal wrapped race cars, and hot rods and is perfect for a quick touch up clean and shine at the car show or race track. Race Wax can be used in direct sunlight and on cars that have not been washed and clean up quick and easy without damaging the paint, windows, chrome or decal graphics.
Product Features:
  • Delivers a Low Drag, High Gloss Finish
  • Effectively Sheds Dirt, Rubber & Debris
  • Quick & Easy Application
  • Clean Up is Simple
  • Perfect for Cleaning & Protecting: Painted Surfaces, Full Decal Wraps, Fiberglass Panels
$9.99 Per Bottle
Driven Racing Oil - Engine Assembly Grease 1 lb. Tub - Part # 00728
Featuring extreme pressure lube that dissolves completely in oil without clogging oil passageways or plugging oil filters. Driven Racing Oil engine assembly grease has been proven to cling to and protect surfaces during initial start-up and delivers applies to cams and lifters for break-in protection you can count on. It can also be used on distributor gears, rocker shafts, rocker tips, pushrod tips, wrist pins and valve guides. Combine with BR series break-in oils to provide proven protection during break-in. Comes in a 1 pound tub.
$21.95 Per Tub
Driven Racing Oil - Engine Assembly Grease 1 oz. Tube - 00732
Same stuff as above, but in a convenient, 1 oz. tube!
$2.99 (Now included in our JDP Camshaft packages!!)
WE INSTALL PARTS!!
If you are looking to have work performed or have one of our packages installed on your vehicle, we have a facility in Sandy, Utah where we perform everything from bolt-on installations, Dyno testing/tuning and complete race car builds. Our install shop fills up fast, so please call us to set up an appointment.
Tyler
801.545.4215
Click HERE to send me a personal message
sales@jdpmotorsports.com
Old 03-11-2014, 07:44 PM   #2
JDP Sales
JDP Sales's Avatar
The LS30 oil contains high Zinc and is specially formulated for LS engines. We have been using it on all of our shop builds and highly recommend it!
Please feel free to call, PM or email me anytime with questions and have a great day!
Best regards,
Tyler
888-308-6007
Old 03-24-2014, 07:18 PM   #3
JDP Sales
JDP Sales's Avatar
Thanks for the orders everyone! Check out our website for more Driven Racing products:
http://www.jdpmotorsports.com/brands/driven-racing-oil
Feel free to call, PM or email us anytime with questions.
Best regards,
Tyler
888-308-6007
Old 04-02-2014, 07:49 PM   #4
JDP Sales
JDP Sales's Avatar
Plenty in stock!
Best regards,
Tyler
888-308-6007
Old 04-28-2014, 08:20 PM   #5
JDP Sales
JDP Sales's Avatar
Wow! This oil is flying off the shelf! Plenty more in stock and ready to ship! We also have the UPF48R filters in stock as well. Feel free to call, PM or email me anytime with questions or Camaro5 pricing!
Best regards,
Tyler
888-308-6007
Old 05-27-2014, 07:06 PM   #6
JDP Sales
JDP Sales's Avatar
Thanks for the orders camaro5! Call, PM or email me for case pricing!
Best regards,
Tyler
888-308-6007
Old 06-05-2014, 08:02 PM   #7
JDP Sales
JDP Sales's Avatar
Thanks for the orders Camaro5! Let us know if you have any questions!
Best regards,
Tyler
888-308-6007
Old 06-05-2014, 08:56 PM   #8
Synner
Drives: not stock
How much for the LS30 by the case?
Old 06-06-2014, 11:39 AM   #9
JDP Sales
JDP Sales's Avatar
PM Sent, Synner.
Best regards,
Tyler
888-308-6007
Old 08-21-2014, 05:22 PM   #10
JDP Sales
JDP Sales's Avatar
Time for a change?
Best regards,
Tyler
888-308-6007
Old 09-16-2014, 08:01 PM   #11
JDP Sales
JDP Sales's Avatar
TTT! Let us know if you have any questions!
Best regards,
Tyler
888-308-6007
Old 10-04-2014, 02:49 PM   #12
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Can you pm me a price on a case of ls30?
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 10-10-2014, 04:37 PM   #13
JDP Sales
JDP Sales's Avatar
PM's and emails have been sent and replied to! Thanks for the orders!!
Best regards,
Tyler
888-308-6007
Old 10-22-2014, 08:40 PM   #14
ddaman922
ddaman922's Avatar
Drives: 2014 Red Hot 1SS M6
Anybody have experience with the STF? I've heard redline is the way to go, but since Joe Gibbs seems to dedicate a whole line of oil to our engines I would imagine they would make a better performing trans fluid. Any input welcome!
ddaman922 is offline   Reply With Quote
best price, driven, jdp motorsports, joe gibbs, racing oil
