Old 01-28-2013, 02:49 AM   #1
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Fuse Pull
What is this?? I've heard it tossed around a lot lately. what is a fuse pull? Can it be done on a 2010 1lt? What does it do??
Trentin24 is offline   Reply With Quote
Old 01-28-2013, 08:22 AM   #2
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
if you have ever put 89 octane in your car...or suspect it, do the fuse pull.
first you will need to run all the fuel under 91 octane out.
my dealer filled up with 89 and i didnt know about the fuse pull.
when i found out, refilled with 93 for 2 tanks(shell) then did the 5 and 20) fuse pull for 12 hours.
you will notice the difference!!!
mine idled better, and performance was noticeably different.
our cars will Go to a low octane fuel table when knock is sensed from low octane fuel and pull timing.
now i use shell 93 or Torco accelerator when i cant get premium.
and stay away from non named brand fuels...lots of alcohol and water in it.
my 2010 loves Shell 93
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 01-28-2013, 08:24 AM   #3
dcoates18481
V8 only i believe.
I LIKE TO GO FAST!
Old 01-28-2013, 09:07 AM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Yes V8 only, manual or automatic. No benefits for the V6.
Old 01-28-2013, 12:07 PM   #5
dcoates18481
It does help the V8's if there ever was 87-89 octame run in it.
i think it can be tuned out too.
I LIKE TO GO FAST!
Old 01-29-2013, 12:53 AM   #6
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
what is the fuse for? I don't understand. The V6 doesn't require premium gas such as 91 or 93 octane. I fill up with 87
Old 01-29-2013, 01:08 AM   #7
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
It doesnt require it but it will perform better with it.
Old 01-29-2013, 01:11 AM   #8
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
What the hell is it? What do you do? What does it do???
Old 01-29-2013, 01:14 AM   #9
lscamaro
lscamaro's Avatar
93 octane
Old 01-29-2013, 01:16 AM   #10
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
93 octane
Doing the fuse pull makes your car think its running on 93 octane?
Old 01-29-2013, 01:17 AM   #11
lscamaro
lscamaro's Avatar
No, the fuse pull does absolutely nothing on our cars.
93 octane helps our cars perform better
Old 01-29-2013, 01:21 AM   #12
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Only 91 available here
Old 01-29-2013, 01:24 AM   #13
lscamaro
lscamaro's Avatar
Even that will help over 87
Old 01-29-2013, 01:27 AM   #14
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Rather not pay the extra 20-30 cents. How does it even help?
