Old 07-12-2013, 12:47 PM   #1
mbober99
mbober99's Avatar
Drives: 2011 Camaro SS
Small tweeters in Component kit to fit in factory pods?
Just curious what people have used in a Component system with tweeters that fit into 2010-2012 Camaro factory tweeter pods in the doors. They rarely give the size specs to know the actual size until you open up the manual after you buy them. Anyone?
mbober99 is offline   Reply With Quote
Old 07-12-2013, 01:21 PM   #2
EM9IRE
EM9IRE's Avatar
Drives: 2011 Convertible 2LT/RS
First link is for an old post on changing the door speakers, the second link is what I found what looks like what was used in the install (previous link). Happy hunting
Front Door Speaker Install Link:
http://www.camaro5.com/forums/showthread.php?t=130857
Amazon Speakers Link:
http://www.amazon.com/Kicker-07DS650.../dp/B000NOKNAA
EM9IRE is offline   Reply With Quote
Old 07-12-2013, 01:28 PM   #3
mbober99
mbober99's Avatar
[QUOTE=EM9IRE;6777217]First link is for an old post on changing the door speakers, the second link is what I found what looks like what was used in the install (previous link). Happy hunting
I meant i was just curious from the people who have replaced them into the stock tweeter pod positions as to the different brands they personally used to see what Models were out there, i have already got a few sets of speakers and none of the tweeters come close to fitting so i will do a custom job making them fit into the a-pillars instead. But i still wasnt to know what may fit the original pods. Thanks btw for those links too.
Old 07-12-2013, 02:03 PM   #4
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I put some Infinity kappas tweeter in the original locations. They was larger then the stack tweeters. I used a dremil tool to cut some of the pods and part of the door pad. They work good.
Caddy
Caddyroger is offline   Reply With Quote
Old 07-12-2013, 02:22 PM   #5
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
I used JL C2's and they fit well. I put some double back tape around them and slide them back into the factory pod.
Old 07-12-2013, 02:47 PM   #6
suzook
Drives: camaro
Anyone just upgrade the tweets, but leave the rest of the stock speakers? I think the highs on the car suck.
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 07-13-2013, 11:31 AM   #7
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
I used the Rockford Fosgate T1652-S components with 1" dome tweeters. The fit was slightly loose, so a couple dabs of hot glue were used to hold hem in place. They do sound better than the stock tweets.
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 07-13-2013, 11:36 AM   #8
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I assume you can do this without door panel removal?
Glen e is offline   Reply With Quote
Old 07-13-2013, 12:24 PM   #9
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
Have you replaced the factory amp yet? It really makes a difference
I'm looking at the JL c2 650 to replace doors....
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 07-13-2013, 12:28 PM   #10
suzook
Drives: camaro
The tweets can be done without removal...but Im wondering if its a worthwhile upgrade just doing the tweets.
Hyperblue/JetBlack
Old 07-13-2013, 01:07 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
just found the DIY on the door removal and it's looks simple -so full JL c2 650's's ordered using ******** adapters...
Old 07-13-2013, 04:25 PM   #12
Chris-10
Chris-10's Avatar
That's exactly what I have, sounds great. Just watch with the adaptor, I figured you could use Atleast one of the factory holes to mount the ******** adapter but the door panel hit on the bottom. Had to drill 3 new hole. Just for your info.
Old 07-13-2013, 05:01 PM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
thx Chris....good info....
Old 07-15-2013, 09:38 PM   #14
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
I used Pioneer TS-T15 tweeters in the pods. It was too much hassle to remove the grilles, so I used a small hole saw and cut out the front of the pods instead. I secured them with some hot glue. By keeping the grilles on the tweeters, I was able to rotate them in more towards the listening position.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
