Old 07-23-2014, 09:07 PM   #1
Rctreece
2013 Victory Red LS3 Vert
Rctreece's Avatar
Drives: 2013 SS/RS
Air suspension
What brand is recommended for camaros? I don't run it at a track just street driving and want a good ride with adjustability and be able to slam it.
Rctreece is offline   Reply With Quote
Old 07-24-2014, 12:25 AM   #2
JCO2185
RIDING ON AIR
JCO2185's Avatar
Drives: 2010 2LT/RS Summit White
Airlift makes a Camaro specific kit. Got it on my car
--John--2010 Camaro 2LT/RS, Summit White
Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels
JCO2185 is offline   Reply With Quote
Old 07-24-2014, 01:11 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
RideTech also has a pretty sweet setup.
Best regards,
Tyler
888-308-6007
Old 07-28-2014, 11:18 AM   #4
Jeremy@AirLift
Drives: 2010 Camaro
Let me know if you have any questions about the Air Lift Performance kit.
Jeremy@AirLift is offline   Reply With Quote
Old 07-28-2014, 11:47 AM   #5
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
AirRex for sure is going to be an option to consider. Pictured below is the AirREX Digital Air Management System. This system is fully assembled and leak tested, within a 30"x12"x10.5" composite wood enclosure, pre-set up, ready for installation. The kit includes a 2.4GHz wireless remote control with three presets. Within the enclosure is a Viair 380C Compressor, which is capable of up to 205PSI. Attached to the compressor is a 3 gallon stainless steel air tank. Also included is a USB cable, power wire kit, and cig lighter adapter. The below picture is the complete system with air struts and air management.
Product Info
Air Struts have a complete bolt on design, and have a 12 click adjustable monotube damper
Allow for a 3-5" drop, depending on your application
Synthetic Rubber Air Springs
Fully Threaded Damper for an additional 2" of static travel
Spanner Wrench Included
1/4" Compression Fittings
ModBargains.com is offline   Reply With Quote
Old 07-28-2014, 01:24 PM   #6
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
Airlift is the way to go. 30 way adjustable dampers... the v2 system is crazy good. I have had airlift for about 4 k miles now and I'll never look back. My car sits on the tires on the front when it's slammed. I need smaller tires. Lol.
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Airlift Suspension V2
Niche Targa 20x10.5
Chris14RS is offline   Reply With Quote
Old 07-28-2014, 04:50 PM   #7
JCO2185
RIDING ON AIR
JCO2185's Avatar
Here is my car on Airlift
Old 07-29-2014, 10:19 AM   #8
fueled by hate
Drives: 2013 2LT Hot Wheels Edition
Either of the kits fbss? Also, how much of a hassle do you think it would be with 21" wheels? My car is attached.
Thanks.
fueled by hate is offline   Reply With Quote
Old 07-29-2014, 10:31 AM   #9
Jeremy@AirLift
Drives: 2010 Camaro
Thanks.
Yes you can do FBSS with the Air Lift kit, you also have the option of using 8 different presets that you can choose. I have seen people running 24"s on the Air Lift kit.
Old 07-29-2014, 11:08 AM   #10
fueled by hate
I shouldn't have to remove the fender liners or roll the fenders though, right?
Old 08-04-2014, 03:11 PM   #11
Jeremy@AirLift
Drives: 2010 Camaro
No you do not have to remove fender liners or roll the fenders.
Old 08-06-2014, 09:12 PM   #12
Rctreece
Rctreece's Avatar
Drives: 2013 SS/RS
How difficult is the install of these kits
Old 08-07-2014, 06:12 AM   #13
marolf101x
Drives: 2010 Test Mule
The Shockwave install (patented air spring and shock combination) is just as simple as any coil over install. . . unbolt the OE struts, bolt in the new Shockwaves.
When you use the AirPod compressor system install is as easy as connecting power, ground and ignition wires, and plugging in the air lines.
You can see it all here:
http://www.ridetech.com/store/muscle...ures_hash=V359
Remember, these are the Fox Racing Shox based dampers which carry a 1,000,001 mile warranty.
Skunk Werks
Ridetech
www.ridetech.com
marolf101x is offline   Reply With Quote
Old 08-07-2014, 12:17 PM   #14
Jeremy@AirLift
Drives: 2010 Camaro
If you have any mechanical skills at all you can install a kit in about 8 hours on jackstands with hand tools. Most everything bolts right in.
