Old 07-28-2011, 04:16 PM   #1
Forza
Drives: 2010 Camaro 2LT/RS CGM
Dex-Cool & Top ups
My 2010 A6 Camaro with 10K kilometers is slightly low on coolant.
I read that one should mix clean tap water with Dex-Cool at a ratio of 50/50.
Do I have to drain the existing coolant first or can I just add more to bring it above the "minimum" level?
Forza is offline   Reply With Quote
Old 07-28-2011, 04:23 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You can just add more, perfectly fine. 50/50 mix with water.
This coolant is good for a recommended 100,000 miles (~161,000km), though I'd recommend to change it about half to 3/4 that mileage.
No need to drain it prior to that, unless of course you get the big mod bug!
- Jeremy
Old 07-28-2011, 04:24 PM   #3
Godon Hutchinson
Godon Hutchinson's Avatar
Drives: 2010 1SS/RS Imperial Blue Metallic
just add what you need to top it off. you should be able to buy coolant thats already a 50-50 mix.
Godon Hutchinson is offline   Reply With Quote
Old 07-28-2011, 05:46 PM   #4
pdesanctis
i like to go fast
Drives: 2011 SS
Please Never put Tap water or Hard water into your cooling system. Distilled water Only.
pdesanctis is offline   Reply With Quote
Old 07-28-2011, 06:27 PM   #5
Stingr69
'69 Owned Since '79
Stingr69's Avatar
+1
Use Distilled Water or buy pre-mixed Dex Cool. Do not get the "compatible with all types" coolant. Trust me on this one.
-Mark.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
Helpful top info. in cold wet weather MS3DALE Camaro Convertible Forum 2 03-06-2014 05:17 PM
Top Gear host Richard Hammond to get own car show on BBC America. Apex Motorsports Off-topic Discussions 11 07-26-2011 10:04 PM
MD UPS CAR CLASSIC SHOW OCT 17th ezleeinfamous USA - Mid-Atlantic 15 10-25-2009 07:06 PM
Test drove a top of the line Mustang and...... av8r Chevy Camaro vs... 19 11-17-2008 04:41 PM
